Reproduce the rendering in the preview... Rules: 1 Cells 1 Free Polygon
1 Connection
Only use the digits 0,1 and 2 in settings (e.g. "201.123") ![]() Njyldgarkn sample cache! |
| Posted: June 13, 2012 2:06 pm | ||||
So is 3 OK, or not? I'm confused |
| Posted: June 13, 2012 3:55 pm | ||||
Please, WHERE should I use only these digits ? Which settings ? I got this interesting and beautiful result that is FAR from the above example but I like it much so I put it here |
| Posted: June 13, 2012 7:35 pm | ||||
| Posted: June 13, 2012 8:12 pm | ||||
SR, Sphinx wrote that. And what's mean digits (sorry, I do not know this word) |
| Posted: June 13, 2012 9:18 pm | ||||
LOL! Yes, Uber sent me that example (just kidding). No I made some mistakes in the number part of the challenge (can't edit post!). Forget the numbers
However I only used the digits 0,1,2 and 5 (sorry about the confusion) - but use that as a hint, not a requirement (if you can make the same image using other numbers, that is accepted). So using those numbers/digits the following examples are allowed "1.5", "215", "0.5" etc (and these numbers goes into the various property fields.. you figure out where) Njyldgarkn sample cache! |
| Posted: June 13, 2012 11:40 pm | ||||
This is pretty cool (I used 2 connections though).![]() "Time flies like an arrow; Fruit flies like a banana." -Groucho Marx |
| Posted: June 14, 2012 8:50 am | ||||
Cool Indigo!
So, you guys want a hint? Njyldgarkn sample cache! |
| Posted: June 14, 2012 9:47 am | ||||
Mongoose King
Here's mine. Almost there, I think I just need a little experimentation to get the numbers right.![]() Release the Mongoose! |
| Posted: June 14, 2012 12:06 pm | ||||
Very good Mongoose! I could be persuaded into calling that a correct answer, but lets see if you can tweak the last few bits. Njyldgarkn sample cache! |
| Posted: June 14, 2012 1:05 pm | ||||
Mongoose King
Here's the next closest. Figured out how to get the multiple rings around the outer blobs. Had loads round at one point :O Found some even crazier patterns while sliding sliders around, this is as close as I'm going, could be tweaking sliders forever to get the exact same look, but I got the technique figured.![]() Release the Mongoose! |
| Posted: June 14, 2012 3:39 pm | ||||
That is close enough Its amazing how so relatively few changes will dismantle that polygon completely! I'll post the solution tomorrow. Njyldgarkn sample cache! |
| Posted: June 14, 2012 4:09 pm | ||||
Mongoose King
Yea, it's hard to figure out what's going on with it, I can kinda see what's happening with it after messing about for a while and pondering on it, but when you first do it, it seems to just be totally unpredictable and not make any sense.
I never considered doing wacky stuff to the polygon until that variable sized dots thread a bit ago. I wonder what other stuff can be done to it. Release the Mongoose! |
| Posted: June 14, 2012 6:40 pm | ||||
as promised.. OneConnection.ffxml Njyldgarkn sample cache! |
| Posted: June 15, 2012 11:42 am | ||||
Mongoose King
ok, hmm, weird.
Cos I had a totally different connection! Sphinx challenge 2.ffxml Release the Mongoose! |
| Posted: June 15, 2012 1:57 pm | ||||
Interesting...
I did something very similar to this, connected the noise to the poligon's rotation. It looked sorta like your puzzle image, but I couldn't find the right settings on the noise to make it look exactly like yours. Nothing worked, now I know why. I never tried squashing the poligon |
| Posted: June 15, 2012 7:08 pm | ||||
15,411 Registered Users
+14 new last day!
+25 new last day!
10,110 Topics
+9 new in 7 days!
