Login - Create Account
Bookmark and Share
Droplets by Skybase
<< 1 2 >>
Droplets by Skybase
http://www.filterforge.com/filters/10802.html
WOW!!! WOW!! I can´t believe you have finally released this filter that you had in your Lab some time ago and that I did fall in love with it, but supossed and thought that this was just a private project, and NOW IS IN THE LIBRARY !!!
Excellent, and very well done, love how the mercury drops are configured from the source image and they look breathtaking for me and amazing textures can be done.
Love it. Thanks very much for uploading this great filter. smile:ff: smile:loveff:
Just one little suggestion, I think would be good to change the name to Mercury Droplets.
And is good that you can use black as a mask and is good to have this, although I wonder if there could be possibly an option to have black mercury drops if you want?
and another version with larger size setting pixels and showing a little source
This is the same as abopve using preset 6 as it is. Really awesome colourful mercury pearls and drops
This is using seamless tiling
With Preset 2
With Preset 2 and reducing the "size pixels" setting to 120 instead of 3000 you get a droplets fine spray that is very detailed following the source
and here is the real size view of the above image so you can the beautiful tiny droplets
Presets 7 looks also cool, is like some organical ice or soft fruits covered in soft ice and water melting
Preset 6 and reducing "size pixels" setting to 510 from 3000
a close up detail of the above here showing the really beautiful mercury droplets so well done and very elegant
Beautiful and lovely colorful mercury droplets stripes
Here is close up detail of the above one here to show how really awesome and amazing quality this filter is able to make
This one and the above (is the same) is on preset 6
And what about a Mercury Lion Head ? smile:D
Preset 6 and size pixel settings reduced much to 208
And here is close up of the above to see the amazing quality of golden melted drops
and here is showing half the source
Color Wheel with preset 6 and size pixels slightly reduced
Color Wheel with preset 6 and size pixels reduced more
Color Wheel with preset 1 showing beautiful and really great and well done corlorful mercury pattern that are really very well joined toghether and looks like metaballs.
This filter deserves to have an EP for it´s high quality and very well done and carefull processing and conversion of the source image
Frozen Color Wheel melting with preset 7
White Tiger head with preset 6, can you see the tiger ? smile:D
White Tiger head with preset 6 reducing size pixels settings to begin to see really some of the tiger head
and here you can see the same as above in closer detail to see the excellent and awesome quality this filter can give and so well done lighting and colors and shadings that looks so beautiful and elegant
Really love what this filter can do and that makes the mercury SO WELL DONE
White Tiger head with preset 6 reducing size pixels settings even more
And here is the real size of the one above that shown the great and beautiful quality and lovely mercury drops
Love much this filter and is really excellent!!!
I was not wrong the first time I have seen this on your Labs thread and thought that this must a great filter but lost the hope of seeing it, and now my dream has come true and is here,
Thanks again for making this elegant and very well done beauty
This kind of awesome filter is what really makes Filter Forge worthy and I can override many of the bad things of FF, specially the speed, and look more at GREAT AND EXCELLENT things that can be done when someone makes filters with such quality and excellence like this one
All the pain and suffering from the bad things of FF is relieved when you can use such a great and well done filter like this one
Here is a closer detail of the above one
and even more closer to see how awesome quality and great lighting and shadings you can get with this filter
Golden Droplets
Also by filling the surroundings where you do not want to have drops, you can mask it with black and then isolate the thing you want to have.
Great shading and lighting can be get with this as you can see in this close up of the above image
And even closer to see the excellence of this filter even better
Golden Orange
more closer of the one above here to the see better the great effect
Droplets Multicolor
And another one
Sorry, have I told you how much I love this filter ? Because I think not smile;) smile:D
And here is the one above here in more closer detail
Skybase in the filter description
If this filter runs a bit slow, you can bypass some of the heavy post effects by pressing "boring mode."
WHAT IS THE BORING MODE ?
One question I want to make is what really is the Boring Mode in the filter, I mean what it does and what is the effect when this is activated ? What is taken out ?
I do not see much difference in quality when this is active or not.
DIFUSSE CHANNEL?
Additinally if you just view the diffuse channel, you can preview how the dots will be placed before the full render.
Sorry to ask what seems to be something probably basic, but where can I see the diffuse channel ?
Who are you?
Filters: 58
The diffuse channel is essentially the color of any surface filter. The general purpose (as described) is basically so you can export color data without the height or reflection data for usage in other programs like Maya. But because we're also not taking into account the lighting for the diffuse map, we're basically bypassing that which gives us a nice way to preview stuff before hand.
You can access the diffuse data fr om the following menu: filter > render maps > diffuse map.
Boring Mode bypasses 2 key nodes: the blur and median blend which basically connects the the droplets together. It visually won't look as different when the droplet sizes are small, wh ere blending is turned down. But you can see the effect of it when you max out the param "Blending Radius" since the check box basically bypasses that. The screenshot below displays the diffuse channel so you can easily see what's happening.
And it's boring because there's nothing cool happening smile:p Just the bomber doing stuff the bomber does all the time.
Thanks very much for the detailed answer, great to know about this
Sorry that I did not know about the filter > render maps > diffuse map, as I have already seen all the possible option of FF but have missed this one.
The FF lifesaver in mercury droplets
Who are you?
Filters: 58
smile;) always check the help docs too!
Thanks for the tip of using the diffuse map to see how the dots will be placed before the full render as this is faster to see a preview as the result is unexpected and do not sure if it will be what you want, so is very good that you can see it this way too until you see it right.
Here is another example that I wanted to make like a fountain of mercury and is very good to be able to mask the surroundings painting all black and then preview how will it look with the difusse map so the dots are not too big, too separate, or too small, and are also some near enough to be joined like metaballs when render.
Really like much the result and love how the drops are shaded and the color applied so well
YES, Sorry, is true that I should have searched there, and is curious that I have never seen this render maps menu until now smile:blush: smile:?: , as I have never used it as I did not need it until now
<< 1 2 >>
15,382 Registered Users
+7 new last day!
+6 new last day!
10,102 Topics
+14 new in 7 days!
13 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
