John Michaud
Student
Filters: 7
I found this little functionality hiccup just now. When you try and set an Intslider to max of 2 at submission the response gives an error. No problem, just set the intslider to a higher max, right? The problem is that it suggests using a checkbox control, which in the case of the switch component, does not return the same results.
I guess its a nitpick at best, but i felt it was a little confusing. Easy enough workaround though, so not a critical bug by any means smile:)
Thanks!
You can turn remapping on and fix this in the remapper properties:
John Michaud
Student
Filters: 7
Whoa... my bad. I guess ill dig a little harder before i call foul next time, heh
thanks for the info Vladimir smile:)
28 unregistered users.
