cashcash
Filters: 6
link 2 set alpha's together in serial.
with an external image into the first 'set alpha' in the chain.
for the first set alpha's mask use a distinct noise or pattern.
for the second set alpha use a destinquishably different noise or pattern.
i've noticed that set alpha's don't work in serial chains.
the first alpha's masking doesn't carry over into the second, instead the last set alpha behaves as though it is getting the original image.
Opacity maps should not already contain transparency. Not the most intuitive concept but its true.
13 unregistered users.
