PogS
Filters: 44
Classic Frame Generator 1.0 by PogS
http://www.filterforge.com/filters/3236.html
PogS
Filters: 44
hint: remove the seamless tiling to get the best out of this filter. You will have better frame shapes and joints between frame parts will be visible :
Really nice patterns on this one!!! Nice work!!! smile:)
You could even convert this one over to wood-carved patterns.....
PogS
Filters: 44
Thanks smile:) This is supposed to be wood painted with gold. I'll try a version with bare wood, why not smile;)
nice patterned wood frame.
i'm hoping you allowed folks to input an image in the contents portion of the frame, yes?
PogS
Filters: 44
No i didn't. Do you have to connect an input to the frame content ? Is that just all ?
yes, just plug an 'image' component into the 'contents' portion of the frame component. or, plug in a switch there and have the image component on one node of the switch and what you've currently got on another. and then add a checkbox to the switch selector and re-map it to control position 1 and 2 for the checking (if you're only using two of the positions. if you're using more of the positions, then use an intslider).
