nemo
Extrapolation - allowing an "opacity" of less than 0% or more than 100% - would be a powerful extension to the Blend component. When used to blend between the original and processed version of an image, it becomes a processing tool in its own right.
For example, a negative blend ("opacity") between the original and a blurred version produces a form of sharpening.
Between the original and a monochrome version it becomes a saturation control, 100%+ turning UP the saturation.
Below 0% when blending between the original and a flat colour introduces a colour cast.
You just blew my mind.
Photoshop doesn't even have that capability.
It would definitely be interesting.
i dont quite follow how you can have an opacity of less than 0% or more than 100%. 0% opaque is simply fully transparent and 100% opaque is simply fully solid. so, i'm a bit lost here how you make that jump in logic and function.
craig
Quasimondo
Quasimondo
Filters: 32
Since Filterforge is internally working with float pixel values theoretically there can be negative values or values that are > 1 (which is like 255). This should allow for all kinds of interesting compositing effects if it gets not artificially limited.
Good idea!
nemo
Craig, you're thinking too physically about the numbers - they're only numbers, not limits.
If you define a blend, where the control 'c' selects between the two inputs 'a' and 'b', one would represent this as
new = a + c * (b - a)
where 'c' varies between 0 to get 'a' and 1 to get 'b' - in your terminology these would be 0% and 100%. However, you still get a result when you use some other value for 'c' - if you used 2, or 200%, the result is new = 2b - a, if you used -1 you'd get new = 2a - b. etc.
Think of it this way, if your two inputs are a colour image, and a greyscale version, then values between 0 and 100% give you various amounts of saturation, values above 100% increase the saturation (possibly to the point of clipping, of course), and values below 0 invert the colours and saturate.
nemo,
no, i dont care if you want to extend the capabilities of something like what you're suggesting. i'm all for options. i just have trouble CALLING it 'opacity' if you go below 0% or above 100%. that's all.
craig
16 unregistered users.
