Torley
Second Lifer
Rough Plastering by Crapadilla
http://www.filterforge.com/filters/4761.html
I'm enjoying using Filter Forge to create http://torley.com/textures
Torley
Second Lifer
Whoa, a new Crapadilla filter! smile:) When I first saw this, the word "realistic" definitely came to mind. I think I'd like to use it with partial opacity on photos and such to give them added texturing. I think if Rough Plastering was applied and made very light and desaturated, it'd also be a fine sort of paper grain for use in other apps like ArtRage.
Another superb work in your oeuvre, Crap! smile;)
ah, NOISE! cool smile:) smile8) thanks, dilla smile:)
ah, NOISE! cool. thanks, dilla
Do I read a little bit of sarcasm there, or is my internet-detector malfunctioning again? smile;)
not sarcasm, but definitely a reference to the noise lab discussion where i asked if you'd post some of your noise filter experiments smile:) (and this is an excellent filter, btw!)
ok, i had a look at the filter, dilla. i added two controls. i added a distortion control on all three noise distortions (one control controlling all three) so i could vary the pattern more and i also added a brightness/contrast after the offset and ran that to the height in the results component and put a control on the contrast and did nothing to the brightness. that allows for more smoothing of the effect.
i'm NOT suggesting you do this as an update. you can if you wish, of course. i just wanted a bit more effect and a bit more control. so, it just extends the range of the filter without changing the base effect or presets.
it's a cool filter. i particularly like the clay effect. that was something i had tried to get months and months ago and gave up on. that was before 'noise lab' and i dont even remember how i tried to achieve that look. all i remember was that i didnt get it and decided to put it aside for a while smile:)
garbanzo
Filters: 58
absolutely amazing. enough said.
Thanks, all.
I would certainly consider it. However, I'm not clear about the purpose of the B/C after the Offset. Couldn't you do something similar with the 'surface height' slider under the lighting tab?
Furthermore, I'd need a good name for the 'distortion' control. 'chaos' is already there...
Magnificent. Another instant Editor's Pick.
James
James
Filters: 46
Great filter very realistic smile:)
Mousse au chocolat is also possible! smile;) smile:D
Very good example of how using Filter Forge You can make photorealistic textures
And I still don't know what's impossible for FF...
We're limited only with our fantasy.
possibly. i was just trying things out. height control in the surface height may be enough by itself. i'll have to look again.
love the mousse smile:)
ok, had another look. you're right about the surface height. it does exactly the same thing. duh! oh well, now you see why i have no editor's picks smile;) congrats on that, btw smile:)
smile8)
Update incoming!
I added a 'Craig' slider... smile;)
now THAT's clay! great sphere smile:) boy, is that what that 'craig' slider does, make 3d spheres? i want one!
Nope, you need a 'crapadilla' slider for that! The 'craig' slider does what you suggested above: tweak the distortion parameter in order to give a wider range of plaster surfaces. smile:)
ah. well, i'll trade you the 'craig' slider for the 'crapadilla' slider any day smile:D
Mike Blackney
Filters: 57
Holy cow, this is great! Nice one smile:D
Thank you, Mike! smile:)
I can only advise filter authors to persue their own "explorations into noise". Many gems lie undiscovered in that area... smile:D
The randomness of patterns and relief is excellent!!! I'll definitely put this one to good use smile:)
You are certainly proving that there is alot more to be done with noise smile:)
It's good to have you back, Steve. smile:)
Thanx Dilla smile:) .....'tremors in the force' and troubles with the 'collective' so to say smile;)
Isn't that the norm these days?! smile;)
I hope not.....I couldn't take another round of it smile;)
Updated:
- Added a 'Detail Level' slider that controls global noise detail. At the default of zero (which is adjusted for the default image size of 600x600) the filter is now significantly faster without visibly sacrificing too much detail!
14 unregistered users.
