The Untaimed
Filters: 6
hey all im having trouble getting filter forge to run in photoshop CS2 i gives an error saying it cant find the exe for it in the path i installed it to, even though the exe is there. it runs ok on its own and if i go into my admin account on my machine it will run ok in CS2
yes i use a limited account for extra internet security...
is there anyway around this other than reinstalling photoshop every time i want to use it...
ive tryed changing the config xml but to no avail
any ideas on how to get it working under my limited account in CS2?
EDIT: just went back to admin account and filterforge gives the same error in CS2
GRRR
This might be too basic and something you have already done, but I just copied the FF plug-in (.8bf) over into my Photoshop plug-ins folder (the FF plug-in should be in the FF folder after you've installed it), and then it opened/ran fine inside Photoshop. I am using an older Photoshop though (V5), so that might not work for CS2, I wouldn't know. You should use the *Contact* form on the site here though, FF responds to that quicker than on the forums usually. smile:)
The Untaimed
Filters: 6
thx ive tried that and it dont work...
The Untaimed
Filters: 6
hmm it seams to be working now...
what i did was completely uninstalled FF and then repaired CS2. Now it seams ok now... but i would still like to know why it happened and what i can do again to avoid it without doing what i just did...
---Not a clue, but glad to hear you did get it working. smile:) You should probably email FF support here, they could most likely help you track down the problem so you can eliminate it permanently.
14 unregistered users.
