| matrix |
Stretch by Corners by ronviers http://www.filterforge.com/filters/5411.html |
| Posted: April 24, 2008 5:55 pm | ||||
Cleanup on aisle four.
Ronivers you might want to request that the FF peeps merge your two versions assuming one of them is now obsolete. |
| Posted: April 24, 2008 5:59 pm | ||||
| matrix |
I didn't even post anything! For a few minutes it seemed like I had hijacked the previous thread simply by clicking "comments"... |
| Posted: April 24, 2008 6:02 pm | ||||
| Posted: April 24, 2008 6:10 pm | ||||
ronviers
It only took a minute to merge them. I added a non-square checkbox. The assumption on the part of the ff users will be that it will only supports square so I can keep the (non-square) suffix. After the new proportional gradient posts I may be able to just drop the internal redundancy If it's fast enough. Presently the time for the square render is 52 sec and the non-square is 3min 52sec. I do not like the idea of merging the 'Add Atmosphere' filters because making the switch would leave so many orphaned controls (unless you can make your 'Any Angle Rotate' non-proportional. I tried and tried to make it non-proportional with both yours and ThreeDee's non-proportional gradients but could not get it to work. I will leave the 'Resize Crop Move' snippets unmerged for ease of use. I have made the non-proportional conversion to other filter but did not need to mention it because the performance hit was not that bad. Thanks Stretch by Corners lsquare non-squarey.ffxml |
| Posted: April 24, 2008 7:06 pm | ||||
15,403 Registered Users
+6 new last day!
+11 new last day!
10,106 Topics
23 unregistered users.
