pixel8ted
Here's an odd one. You'll notice in the image that the controls indicate that the Profile Gradient is set to repeat once with 0 offset. The Profile Gradient...and any I pull from the component area...do not, however, go below three repeats with this filter file. I tried Select All and Clear to remove all components but ALL the profile gradients act the same way with this filter...or any built in this filter workspace. The Profile Gradients work as expected if I build in a fresh work area. Here's a screen shot of the offending filter work area with a Profile Gradient displaying this behavior:
Terri
pixel8ted
If I copy all components and put them into a fresh workspace, the profile gradients behave as expected.
Terri
onyXMaster
Filter Forge, Inc.
Be sure to check the Size slider in filter controls.
pixel8ted
onyXMaster,
Thanks! It was the Size slider in filter controls causing this behavior.
Terri
17 unregistered users.
