ALZHEM
Filters: 11
- Crop: a node where you could easily crop the part you need
- Rotation: if you want to easily rotate the image 90º, 45º...
- Row Shift in the BOMBER, or applying an image (or result of nodes) per tile in TILES
- Searching and downloading filter from the online library straight from FF instead of depending on a browser
ALZHEM
Filters: 11
Another wish I posted in the wrong section:
I've found slightly annoying to look for all the filters I use every time I format. Wouldn't it be great that our account would also store in a way the filters we have in a "Favorites" section? Probably just the number of the filter would do it (that shouldn't be too much data for the server), so if we clean our machine we could also download those filters back with a "Download favorites filters from the server" option.
KGtheway2B
KGtheway2B
You can grab the physical filter files from your computer before you format. Just click Ctrl+L to open the folder that contains the current filter. If you do this once for your "My filters" and once for any other category and copy all the filters located in those folders you will have gotten a complete backup.
Also: Rotation is a pretty common request.
Cropping I'm sure is common too, but how would you suggest it would work?
ALZHEM
Filters: 11
Hi KGtheway2B smile:)
I know I can do the backup that way, but is good to think the standard user doesn't like to use the OS to do handmade backups (that's why browsers are adding that cool feature right now).
Cropping would be something like Photoshop's Crop tool, but much easier. In Photoshop you create that box, double click in the middle and get the new picture. Here, it could be something like you have the Source to connect other nodes to, and then 4 options: Top, Bottom, Left and Right. By default all would be at "0", what would mean "no cropping action", and the values could be a percentage. If you move Top to 10%, that'd mean the top 10% of what is plugged to this node would disappear, leaving the image a bit stretched horizontally. If I ask for this, is because lots of times when you create something you want to repeat, the result of mixing the first nodes is good, but is not adjusted to the borders.
Also, another good thing for the wish list could be a "Scale". You can see that the Transform tool from Photoshop is missed smile:)
28 unregistered users.
