scriptorum
Fella
Filters: 7
This is a very minor issue but it's confused me a couple times. When you make a change on a text field for an existing input in the input editor and then immediately click OK, your changes will not be saved.
To reproduce, go to the Input Editor in a Map Script, click on an existing input, click on a text field (e.g., Display Name), modify or type in a new value, then click OK. The value is not saved. However, after typing in the new value, if you click on another text field or hit TAB just to change focus, the change will stick.
Thanks for reporting, the issue has been reproduced.
The fix should be available in the next update.
We have released a hotfix: you can download and reinstall the setup package from the download page to fix this issue.
scriptorum
Fella
Filters: 7
Thanks.
