Peter Beckley
To reproduce select any filter, then select a preset other than than the preset. Switch to another filter. Switching back to previous filter highlights the default, but applies the last chosen preset, which in the test case is not the default.
Solution: highlight applied preset or apply default preset when switching filters.
Thank you, the issue has been confirmed.
Mmm.. is this really a bug? It is not simply the last used preset, it is the last used settings. I find it useful that the last tweaked settings are active when you return to a filter (during the session). However it is not very smart that the preset selection highlights the default preset. Perhaps you should not highlight anything in case of unsaved tweaked settings
17 unregistered users.
