Bionic
Submitted via built-in bug reporting tool,
Filter library -> when switching -> hide/show downloaded filters
| Code |
<class XFW::Kernel::StdException> bad allocation
Operating system: x64 Edition (6.1 build 7600)
Physical memory: 8190 MB
Number of processors: 8, available: 8
Processor info: Intel® Core i7 CPU 920 @ 2.67GHz, ~3175 MHz
Filter Forge x86-SSE2 3.003.21817.36898 Release-SSE2, August 31, 2011 09:48 [2011-09-06 13:53:35 W. Europe Daylight Time]
[Controls::Control] Exception occured while processing window message 0x0000000F(WM_PAINT) (0x00000000 0x00000000) for window 005C0ABC/005C0ABC, control: <class Controls::ListView>@140F2D60.
Exception reported at thread 00000EE4 'RenderingMgr 7E886EF0/0':
Possible original exception location:
<unknown file>(0) : <unknown function>()+0 at 0066A044 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006B991F in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00719A47 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00719D46 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006E03A7 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006DDE99 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006FC57B in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 007721E7 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006BB5A0 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006F8569 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0066B8F7 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006BEBA0 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:757FB727, SS:ESP 002B:0413E28C, EBP 0413E2DC, FLAGS 00000202
CONTEXT_INTEGER: EAX 0413E28C, EBX 00000898, ECX 00000003, EDX 00000000, ESI 00AE69A4, EDI 0413E31C
[FFXLib::RenderingManager] Failed filter dump:
<?xml version="1.0" encoding="utf-8"?>
<Filter>
<Components>
<Result id="result">
<SurfaceColor source="switch3 01" red="1" green="0" blue="1" alpha="1"/>
<Height source="switch3 02"/>
<Reflectivity source="blend5 05" value="0.37"/>
<ReflectionBlur value="0.84999999999999998"/>
<Met allic value="1"/>
<FilterType value="1"/>
<Lighting>
<Height value="0.20000000000000001"/>
<Environment>
<Source value=""/>
<Brightness value="1"/>
<Saturation value="1"/>
<Rotation value="0"/>
<RotationAxis x="0" y="0" z="0"/>
</Environment>
<Ambience>
<AmbientLight red="0" green="0" blue="0"/>
<Shadowing value="0"/>
<CurrentOcclusionSettings>
<RayDirections value="4"/>
<TraceDistance value="0.20000000000000001"/>
<RayJittering value="true"/>
<RayBounce value="true"/>
<AvoidStreaks value="true"/>
<DirectSamples value="0"/>
<ROQuality value="3"/>
</CurrentOcclusionSettings>
<CustomOcclusionSettings>
<RayDirections value="16"/>
<TraceDistance value="0.29999999999999999"/>
<DirectSamples value="1"/>
<ROQuality value="10"/>
</CustomOcclusionSettings>
<ArtisticSettings>
<BlackPoint value="0"/>
<Midtones value="0.5"/>
<WhitePoint value="1"/>
</ArtisticSettings>
</Ambience>
</Lighting>
</Result>
<Blend5 id="blend5 01">
<Mode value="6"/>
<Foreground source="profilegradient2 02" red="1" green="1" blue="1" alpha="1"/>
<Background source="profilegradient2 01" red="0" green="0" blue="0" alpha="1"/>
<Opacity value="1"/>
</Blend5>
<Blend5 id="blend5 02">
<Mode value="2"/>
<Foreground source="stones2 01" red="1" green="1" blue="1" alpha="1"/>
<Background source="perlinnoise2 01" red="0" green="0" blue="0" alpha="1"/>
</Blend5>
<Blend5 id="blend5 03">
<Mode value="2"/>
<Foreground source="invert 01" red="1" green="1" blue="1" alpha="1"/>
<Background source="highpass2 01" red="0" green="0" blue="0" alpha="1"/>
</Blend5>
<Blend5 id="blend5 04">
<Mode value="6"/>
<Foreground source="blend5 01" red="1" green="1" blue="1" alpha="1"/>
<Background source="setalpha2 01" red="0" green="0" blue="0" alpha="1"/>
</Blend5>
<Blend5 id="blend5 05">
<Mode value="9"/>
<Foreground source="perlinnoise2 02" red="1" green="1" blue="1" alpha="1"/>
<Background source="blend5 03" red="0" green="0" blue="0" alpha="1"/>
</Blend5>
<Blend5 id="blend5 06">
<Mode value="2"/>
<Foreground source="highpass2 01" red="1" green="1" blue="1" alpha="1"/>
</Blend5>
<Blend5 id="blend5 07">
<Mode value="2"/>
<Foreground source="perlinnoise2 03" red="1" green="1" blue="1" alpha="1"/>
<Background source="blend5 05" red="0" green="0" blue="0" alpha="1"/>
</Blend5>
<Blend5 id="blend5 08">
<Mode value="2"/>
<Foreground source="perlinnoise2 04" red="1" green="1" blue="1" alpha="1"/>
<Background source="threshold2 02" red="0" green="0" blue="0" alpha="1"/>
<Opacity value="0.65000000000000002"/>
</Blend5>
<CheckboxControl id="checkboxcontrol 01">
<Name value-en="Middle Rotate"/>
<UseRemapping value="false"/>
<Checked value="false"/>
</CheckboxControl>
<ColorControl id="colorcontrol 01">
<Name value-en="Stain Color 1"/>
<Color red="0.48062015503875966" green="0.40685924806692575" blue="0.12294934198665945" alpha="1"/>
</ColorControl>
<ColorControl id="colorcontrol 02">
<Name value-en="Stain Color 2"/>
<Color red="0.21453294883459045" green="0.34496124031007747" blue="0.053482362838771717" alpha="1"/>
</ColorControl>
<ElevationGradient3 id="elevationgradient3 02">
<Elevation source="threshold2 02"/>
<Gradient source="profilegradient2 04"/>
<Flip value="true"/>
<Repeat value="1"/>
</ElevationGradient3>
<GainCurve id="gaincurve 01">
<Gain value="0.66000000000000014"/>
<Start value="0"/>
<End value="0.81000000000000005"/>
<Minimum value="0"/>
<Maximum value="1"/>
<Invert value="false"/>
</GainCurve>
<Gamma2 id="gamma2 01">
<Source source="blend5 07"/>
<Gamma source="slidercontrol 01" value="0.10000000000000009">
</Gamma>
</Gamma2>
<HighPass2 id="highpass2 01">
<Source source="blend5 04"/>
<Radius value="0.11"/>
<Contrast value="0.92000000000000004"/>
<Monochrome value="true"/>
</HighPass2>
<ImpulseCurve id="impulsecurve 01">
<Position value="0.69999999999999996"/>
<Width source="intslidercontrol 01" value="1">
<Minimum value="0.20000000000000001"/>
</Width>
<Plateau value="0.5"/>
<Shape1 value="0.80000000000000004"/>
<Shape2 value="1"/>
<Balance value="0.23000000000000001"/>
<Smooth value="true"/>
</ImpulseCurve>
<ImpulseCurve id="impulsecurve 02">
</Width>
<Shape2 value="1"/>
</ImpulseCurve>
<ImpulseCurve id="impulsecurve 03">
<Width source="intslidercontrol 02" value="1">
</Width>
<Plateau value="0.27000000000000002"/>
<Shape1 value="0.73999999999999999"/>
<Shape2 value="1"/>
</ImpulseCurve>
<IntSliderControl id="intslidercontrol 01">
<Name value-en="Trim Width"/>
<UseRemapping value="true"/>
<Value value="71"/>
<RangeMax value="100"/>
</IntSliderControl>
<IntSliderControl id="intslidercontrol 02">
<Name value-en="Middle Width"/>
<Value value="97"/>
</IntSliderControl>
<IntSliderControl id="intslidercontrol 04">
<Name value-en="Middle Repeat"/>
<Value value="1"/>
<RangeMax value="20"/>
</IntSliderControl>
<IntSliderControl id="intslidercontrol 05">
<Name value-en="Trim Repeat"/>
<Value value="1"/>
<RangeMax value="10"/>
</IntSliderControl>
<IntSliderControl id="intslidercontrol 07">
<Name value-en="Detail Option"/>
<Value value="1"/>
<RangeMax value="5"/>
</IntSliderControl>
<IntSliderControl id="intslidercontrol 08">
<Name value-en="Detail Variation"/>
<Value value="1"/>
<RangeMax value="1000"/>
</IntSliderControl>
<Invert id="invert 01">
<Source source="blend5 02"/>
</Invert>
<Kaleidoscope2 id="kaleidoscope2 01">
<Mode value="2"/>
<Source source="gamma2 01"/>
<OffsetH value="0.10000000000000001"/>
<OffsetV value="0.10000000000000001"/>
<ShapeSize source="slidercontrol 02" value="0.25">
</ShapeSize>
<RepeatH value="1"/>
<RepeatV value="1"/>
</Kaleidoscope2>
<NoiseCurve id="noisecurve 01">
<Roughness value="0.20999999999999999"/>
<Amplitude value="0.75"/>
<Scale value="1.6000000000000001"/>
<Details value="0.40000000000000002"/>
<Variation value="1"/>
<Periodic value="false"/>
<Randomizable value="false"/>
</NoiseCurve>
<PerlinNoise2 id="perlinnoise2 01">
<Noise red="1" green="1" blue="1" alpha="1"/>
<Background red="0" green="0" blue="0" alpha="1"/>
<Roughness value="0.92000000000000004"/>
<Scale value="2.73"/>
<Stretch value="0"/>
<Angle value="0"/>
<Details value="1"/>
<Contrast value="0.10000000000000001"/>
<OctaveCurve value="0"/>
</PerlinNoise2>
<PerlinNoise2 id="perlinnoise2 02">
<Noise source="perlinnoise2 01" red="1" green="1" blue="1" alpha="1"/>
<Background source="invert 01" red="0" green="0" blue="0" alpha="1"/>
<Roughness value="0.95000000000000007"/>
<Scale value="2.5"/>
<Angle value="0"/>
<Contrast value="0"/>
</PerlinNoise2>
<PerlinNoise2 id="perlinnoise2 03">
<Noise source="perlinnoise2 02" red="0" green="0" blue="0" alpha="1"/>
<Background red="0" green="0" blue="0" alpha="0"/>
<Roughness value="0.70999999999999996"/>
<Scale value="2.5500000000000003"/>
<Angle value="82"/>
<Contrast value="0.54000000000000004"/>
<Variation value="7074"/>
<OctaveCurve value="2"/>
</PerlinNoise2>
<PerlinNoise2 id="perlinnoise2 04">
<Noise source="perlinnoise2 02" red="1" green="1" blue="1" alpha="1"/>
<Roughness value="0.67000000000000004"/>
<Scale value="2.4300000000000002"/>
<Angle value="0"/>
<Contrast value="0.80000000000000004"/>
<Variation source="intslidercontrol 08" value="7806">
<Step value="1"/>
<Offset value="0"/>
</Variation>
<OctaveCurve source="gaincurve 01" value="2"/>
</PerlinNoise2>
<ProfileGradient2 id="profilegradient2 01">
<Color1 red="0" green="0" blue="0" alpha="1"/>
<Color2 red="1" green="1" blue="1" alpha="1"/>
<Offset value="0"/>
<Rotate value="3"/>
<Repeat source="intslidercontrol 05" value="1">
<Step value="1"/>
<Offset value="0"/>
</Repeat>
<Profile source="impulsecurve 01" value="0"/>
<Mirror value="false"/>
</ProfileGradient2>
<ProfileGradient2 id="profilegradient2 02">
<Offset value="0"/>
<Rotate value="1"/>
<Step value="1"/>
<Offset value="0"/>
</Repeat>
<Profile source="impulsecurve 02" value="0"/>
</ProfileGradient2>
<ProfileGradient2 id="profilegradient2 03">
<Offset value="0"/>
<Rotate source="checkboxcontrol 01" value="1">
<Checked value="0"/>
<Unchecked value="1"/>
</Rotate>
<Repeat source="intslidercontrol 04" value="1">
<Step value="1"/>
<Offset value="0"/>
</Repeat>
<Profile source="remapamplitudecurve 01" value="0"/>
<Mirror value="true"/>
</ProfileGradient2>
<ProfileGradient2 id="profilegradient2 04">
<Color1 red="1" green="1" blue="1" alpha="0"/>
<Color2 red="0" green="0" blue="0" alpha="1"/>
<Offset value="0"/>
<Rotate value="0"/>
<Repeat value="1"/>
<Profile source="gaincurve 01" value="1"/>
</ProfileGradient2>
<RemapAmplitudeCurve id="remapamplitudecurve 01">
<Source source="impulsecurve 03"/>
<Remap source="noisecurve 01"/>
</RemapAmplitudeCurve>
<SetAlpha2 id="setalpha2 01">
<Source source="profilegradient2 03" red="1" green="0" blue="0" alpha="1"/>
<NewAlpha source="threshold2 01" value="1.2749999999999999"/>
<InvertAlpha value="true"/>
</SetAlpha2>
<SliderControl id="slidercontrol 01">
<Name value-en="Gamma"/>
<Value value="0.32000000000000001"/>
</SliderControl>
<SliderControl id="slidercontrol 02">
<Name value-en="Detail Shape Size"/>
<Value value="0.25"/>
</SliderControl>
<Stones2 id="stones2 01">
<Noise source="colorcontrol 01" red="1" green="1" blue="1" alpha="1"/>
<Background source="colorcontrol 02" red="0" green="0" blue="0" alpha="1"/>
<Roughness value="0.89000000000000001"/>
<Contrast value="0.26000000000000001"/>
<Fo rmula value="0"/>
<Scale value="0.93000000000000005"/>
<Stretch value="0.16"/>
<VerticalStretch value="false"/>
<Flat value="false"/>
<SolidFill value="false"/>
</Stones2>
<Switch3 id="switch3 01">
<Source1 source="gamma2 01" red="1" green="0.066000000000000003" blue="0" alpha="1"/>
<Source2 source="threshold2 02" red="1" green="0.77200000000000002" blue="0.113" alpha="1"/>
<Source3 source="kaleidoscope2 01" red="1" green="1" blue="0.16800000000000001" alpha="1"/>
<Source4 source="elevationgradient3 02" red="0.125" green="1" blue="0.184" alpha="1"/>
<Source5 source="tonecurve2 01" red="0" green="1" blue="1" alpha="1"/>
<Source6 red="0" green="0.76000000000000001" blue="1" alpha="1"/>
<Source7 red="0" green="0" blue="0.99199999999999999" alpha="1"/>
<Source8 red="0.996" green="0" blue="0.98799999999999999" alpha="1"/>
<Source9 red="0" green="0" blue="0" alpha="1"/>
<Source10 red="0.5" green="0.5" blue="0.5" alpha="1"/>
<Source11 red="0.74099999999999999" green="0.74099999999999999" blue="0.74099999999999999" alpha="1"/>
<Source12 red="1" green="1" blue="1" alpha="1"/>
<Selector source="intslidercontrol 07" value="1">
<Step value="1"/>
<Offset value="0"/>
</Selector>
</Switch3>
<Switch3 id="switch3 02">
<Source1 source="threshold2 02" red="1" green="0.066000000000000003" blue="0" alpha="1"/>
<Source2 source="blend5 08" red="1" green="0.77200000000000002" blue="0.113" alpha="1"/>
<Step value="1"/>
<Offset value="0"/>
</Selector>
</Switch3>
<Threshold2 id="threshold2 01">
<Source source="blend5 01"/>
<Threshold value="0.5"/>
<Smooth value="0.23999999999999999"/>
<Low red="0" green="0" blue="0" alpha="1"/>
<High red="1" green="1" blue="1" alpha="1"/>
</Threshold2>
<Threshold2 id="threshold2 02">
<Threshold source="perlinnoise2 02" value="0.19"/>
<Smooth value="0.58999999999999997"/>
<Low source="blend5 06" red="0" green="0" blue="0" alpha="1"/>
</Threshold2>
<ToneCurve2 id="tonecurve2 01">
<Source source="kaleidoscope2 01"/>
<Curve source="gaincurve 01"/>
<PreserveColor value="true"/>
</ToneCurve2>
</Components>
<Presets>
<DefaultPreset>
<Settings size_factor="1" variation="1" seamless="true" antialiasing="2" map_type="0" edges_only="true" clip_hdr_for_result="true"/>
<Lighting>
<Environment>
<Source value=""/>
</Environment>
<Ambience>
<ArtisticSettings>
</ArtisticSettings>
</Ambience>
</Lighting>
<Controls>
</CheckboxControl>
</ColorControl>
</ColorControl>
<Value value="71"/>
</IntSliderControl>
<Value value="97"/>
</IntSliderControl>
<Value value="1"/>
</IntSliderControl>
<Value value="1"/>
</IntSliderControl>
<Value value="1"/>
</IntSliderControl>
<Value value="1"/>
</IntSliderControl>
</SliderControl>
</SliderControl>
</Controls>
</DefaultPreset>
</Presets>
</Filter>
[FFXLib::RenderingManager] Rendering settings dump:
Seed: 1
Seamless: true
Optimize blur radius: true
Supersample explicit inputs: false
Output size: 331x331
Sampling rate: 1
Supersampling kernel: 2
Jitter: 0
Bruteforce: false
High precision bitmap: false
Blend with original image: false
[FFXLib::RenderingManager] Rendering storage: <class FFX::PreviewRenderingStorage>@17B9ED30
[FFXLib::RenderingManager] Failed rendering block dump:
Block origin: 0;0
Root component: result
Progressive pass: 4
Exception caught at thread 000011F8 'Application':
<class XFW::Kernel::StdException> bad allocation | |
| Posted: September 6, 2011 7:13 am |
Details
E-Mail
Can you reproduce this? If yes, please provide the detailed step-by-step instruction. |
| Posted: September 6, 2011 8:05 am |
Details
E-Mail
Bionic
Can try, could be that I'm downloading many filters and there's lots of thumbnailing in the background.
I'm kinda pushing it to the limits while it's working, but deliberately |
| Posted: September 6, 2011 8:13 am |
Details
E-Mail
Bionic
yes i could.. when clicked misc in filter library this occured again
I could not submit report hence buttons greyed out? (attached screenshot)
But I found ~tmp file, will see if it's usable
It seem different than this report
| Posted: September 6, 2011 8:34 am |
Details
E-Mail
Bionic
sent |
| Posted: September 6, 2011 8:42 am |
Details
E-Mail
Bionic
a third sent of <class XFW::Kernel::StdException> bad allocation
filter library @distortions |
| Posted: September 6, 2011 8:48 am |
Details
E-Mail
Bionic
A fourth sent of <class XFW::Kernel::StdException> bad allocation
When going back from Filter library "distortions" to UI clicking on Filter thumbs in organic
| Posted: September 6, 2011 8:55 am |
Details
E-Mail
Bionic
a fifth sent of <class XFW::Kernel::StdException> bad allocation
when going back from previous crash @filter library distortions" to UI clicking on actual pixels |
| Posted: September 6, 2011 8:59 am |
Details
E-Mail
Bionic
a sixth sent of <class XFW::Kernel::StdException> bad allocation
when going back from previous crash @filter library distortions" to UI clicking edit filter.
I'll now pause submitting XFW::Kernel::StdException
Unless you want more or I'll stumble upon elsewhere |
| Posted: September 6, 2011 9:05 am |
Details
E-Mail
