Login - Create Account
Bookmark and Share
Version 3.0 (release) Install Problem
jilbert
a Jill of all trades
Filters: 7
I downloaded and installed Version 3.0 today and there's a problem with the permissions. While I was able to fix them using the console, others may not know how to do it. Just thought I'd let you know ...
steveshead
Steve Shead
I had the same issue, and used the same resolution - just adding a voice to the issues.
cfree68
colin Fizgig
Filters: 22
What is the resolution for this? I have the same issue but do not know how to fix it.
colin Fizgig
You need to change the access rights for the Filter Forge folder. Please follow these steps:
1. Click the Filter Forge folder in Applications.
2. Select 'Get Info' -- a pane will open.
3. If your user name is there in the user list, set the permissions to 'Read and write'. If your user name isn't listed click the '+' button and add the user to the list, then set the permissions to 'Read and write'. You might need to click the small lock icon at the bottom of the pane and enter an admin password to unlock the permissions box.
4. After you finish setting the permissions, don't forget to click the lock icon again -- to 'lock' the choice.
15,510 Registered Users
+7 new last day!
+55 new last day!
10,191 Topics
+10 new last day!
Recent Wiki Edits:
Follow filterforge on Twitter
