Login - Create Account
Bookmark and Share
Escher Forest by CFandM
Schaunmermal
http://www.filterforge.com/filters/10086.html
Filters: 59
That Depth Map input just had to be good for something, after all. smile;) smile:D
Filters: 207
Yep had to be useful somewhere... smile;) smile:)
Filters: 91
Very nice and for sure... useful. Thanks for this filter CFandM smile:)
Filters: 88
Cool, and not too surprisingly, it's from Mr. 3-D himself smile:p
Filters: 207
You are welcome and Thanks Ghislaine...
smile:D smile;)
Filters: 97
escher makes my head hurt. nice job, CF smile:) now make em 3d!! smile:D
Filters: 207
hehe.. smile;) smile:D
I was in the process of that but ran into a little issue with the standard method.....Don't quite know if its a bug in the offset or if the offsets handle images differently....Or if its because its running through the bomber...I tried some basic noises with this method and it works..But heres the problem......
Connected to extract each channel(RGB) then connected to the AssembleRGB....
Filters: 207
Then add the offset to the red channel for movement with all of the settings on the offset at 0.....So this is in the same position..So there should be no red.....
Filters: 207
Had an ideal and just checked it.....Looks like the offset is off when connected this way for some reason......With the Horizontal setting at 1 fixes this issue...Which could be a bug since everything at 0 would not allow it to move........
15,510 Registered Users
+7 new last day!
+53 new last day!
10,191 Topics
+10 new last day!
Nebreah2, angelize, GMM, 26 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
