GeorgeR
As a map script, this produces an incorrect result. Change r to 3 in the remapSample function to see what it should look like. Using FF 3.0.
Code
r = 3
function prepare()
end;
function remapSample(x, y)
   return (x * r) % 1, (y * r) % 1
end;
function get_sample(x, y)
   r, g = remapSample(x, y)
   return r, g, 0
end;
Dmitry Sapelnikov
Filter Forge, Inc. AKA Egret
Filters: 5
Declare the r and g variables in get_sample() as local.
The get_sample() function doesn't work well because it accidentally overrides the global r variable.
The original code:
Code
   // here you rewrite the global r = 3
   return r, g, 0
end;
The fixed code:
Code
   // this will work correctly
   local r, g = remapSample(x, y)
   return r, g, 0
end;
