Login - Create Account
Bookmark and Share
Can´t find a special filter
Hades
Hi everybody !
Maybe some good soul can help me? I was now browsing the filter for a long time for a special filter. But can´t find it smile:(
Whats the name of this Van Gogh style filter wich is on the mainpage ? The filter in the advertising
"The best Photoshop plugin
Filter Forge 3.0 Is Out!"
Can someone tell me please under wich category i can find this filter and the name of it ?
Thank you in advance for your help!
Ok now found out that name is van gogh but it crashes filter forge smile:( where i can remove this filter manually because it crashes at startup smile:(
Hades
Hades
So i figured out that the van gogh filter crashes Filter Forge 3.07 ! I had to delete all filters otherwise i couldnt open filter forge no more !
Can someone confirm this ?
I am working under Mac OSX Lion
Are you looking for this filter ?
Van Gogh Flow by Darrell Plank
http://www.filterforge.com/filters/9817.html
I can´t tell about MAC issues, as I am on windows 7
inujima
Van Goph Flow filter is using Map Script component.
At MAC OS, FF crashes by high probability (or 100% ?) when a bitmap based component like Blur is included in the subtree of a script component.
http://www.filterforge.com/forum/read...6&TID=7764
It is best that FF team correct this bug, but it has been left for long time, it cannot be expected.
The most effective solution at present is to remake the section of the map script without using it.
inujima
Try this filter.
Van Gogh Flow without script.ffxml
Hades
Hi Inujima !
Thank you so much for helping me !
Is there a way to see how this filter is build up so i can learn something ?
Thank you in advance !
Hades
olderdog
Inunjima:
Thanks a lot, that works fine and I like the filter. It would seem that FF would post a warning and that the creator would prefer what works. ( know he was surprised a the problem. Thanks again. Now all I have to do is figure out how to remove the broken filter, but at least I can get ff to load.
Darrell Plank
Filters: 4
Inujima -
Great job! I should have done this a while ago but was hoping that FF would fix their bug and perhaps a bit lazy. Well, probably mostly just lazy - lol. Great fix!
Darrell
Darrell
15,514 Registered Users
+30 new in 7 days!
+34 new last day!
10,192 Topics
+32 new in 7 days!
jffe, 6 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
