Predefined Adjustment Controls Snippet by SpaceRay http://filterforge.com/filters/10568.html |
| Posted: April 24, 2012 2:45 am | ||
Hello,
As I was making my last filter I thought that it is very tedious to add the adjustments controls every time fr om the components panel and then you need to add the controls and configure the values to the default right ones, and that it takes much time that can be saved much having this snippet wh ere is all already done. So I have made this Snippet that could help you to add the components of Hue, Saturation, Brightness, Gamma, Contrast and Levels to your own filters in a easy and fast way. They are already predefined with the default values so they are "transparent" or invisible unless you change the values. You can replace the first image component with the source of your own filter source. USING AS STANDALONE FILTER Of course that this can be used ALSO as a normal filter to adjust the source images that you wish as you do not need to add it to another filter to use this. PRESETS The presets are not much useful, just made them for the submit wizard for FF online library so they are not generated randomly. You can configure yourself your own ones. |
| Posted: April 24, 2012 2:51 am | ||
No ability to download your filter. I sent the report to FF. I dont understand why this happens. | |
| Posted: April 24, 2012 9:08 am | ||
Hello Ghislaine, I have downloaded the filter without problem. I do not know what could happen. | |
| Posted: April 24, 2012 11:38 am | ||
Ok now I get it. The problem was that my FF was closed. So I just had to open it after what I was able to download your filter. This is happened with another filter too. But everything is fine now. | |
| Posted: April 24, 2012 2:04 pm | ||
After readin on others threads about the Macros feature wish to be included inside FF I wonder if this Macros would be possible to make groups of components like this and make it all in one component BUT MOST IMPORTANT with all the control components settings already attached and linked so you do not have to link them and just add them to the filter editor in whole.
This is why I have made this snippet, To be able to open it, copy the parts I need to paste to a filter with the component and controls already configured and linked and be able to take it to another filter, fast and easily |
| Posted: August 30, 2012 10:28 am | ||
15,403 Registered Users
+6 new last day!
+11 new last day!
10,106 Topics
24 unregistered users.
