Polar to cartesian and back by Nebukadnezar http://filterforge.com/filters/10577.html |
| Posted: April 27, 2012 8:54 am | ||||||
Interesting useful snippet. Like how it is done and is good to learn too.
This can be used to interesting effects. Thanks very much |
| Posted: April 27, 2012 8:55 am | ||||||
Thanks! For some reason, I can't download this filter, but the link in my filter comments works. "Time flies like an arrow; Fruit flies like a banana." -Groucho Marx |
| Posted: April 27, 2012 2:35 pm | ||||||
Oh sweet stuff. Can totally use this for tons of awesome. | |||||
| Posted: April 27, 2012 8:57 pm | ||||||
| Nebukadnezar |
Thx, guys! Indigo, I updated it yesterday, because I had mixed up the description of the controls. Might be that caused your problem. |
| Posted: April 28, 2012 9:51 am | ||||||
Looks great. Makes me wish I had a clue, so I could use it |
| Posted: April 28, 2012 4:48 pm | ||||||
Well, I really have been looking at it, and really the same as you I do not have a clue how to use this inside a filter. This filter has been done after the Indigo Ray request here
Although I do not know how to use this inside a filter it STILL IS A USEFUL FILTER You can create weird distorsions |
| Posted: April 28, 2012 11:38 pm | ||||||
another one |
| Posted: April 28, 2012 11:39 pm | ||||||
Here is a close up of a tulip flower through this filter |
| Posted: April 28, 2012 11:40 pm | ||||||
Can convert a circular shape into a linear shape |
| Posted: April 28, 2012 11:41 pm | ||||||
one more |
another |
| Posted: April 28, 2012 11:42 pm | ||||||
Can convert a circular shape into a linear shape AND linear shapes into curves (you can see how the white frame has been converted |
| Posted: April 28, 2012 11:43 pm | ||||||
Here are some stripes rainbow lines to see what how is the distorsion done
Here are vertical stripes |
| Posted: April 29, 2012 12:02 am | ||||||
And this are horizontal stripes |
| Posted: April 29, 2012 12:03 am | ||||||
And here are another kind of vertical stripes |
| Posted: April 29, 2012 12:12 am | ||||||
And what happens if you want to make a big Niagara style waterfall from a city skyline?, well here is one example of an aerial syline of New York converted with this filter into a waterfall |
| Posted: April 29, 2012 12:15 am | ||||||
And another example of circle to linear conversion
THIS AND ALL THE ABOVE EXAMPLES HAS BEEN DONE USING THE SETTING 2 ON THE SLIDER |
| Posted: April 29, 2012 12:16 am | ||||||
I know how to use this inside a filter, but my problem is when I go from cartasian to polar, lines get wider and wider as they move further away from the center.
I need to figure out a way to distort thing BEFORE they enter the cartasian to polar... And other stuff after that |
| Posted: April 29, 2012 2:53 am | ||||||
Perhaps this happens because the lines are running away from the cold of the polar |
| Posted: April 29, 2012 3:06 am | ||||||
I also wanted to see what happens when you transform a Polar (bear ![]() |
| Posted: April 29, 2012 3:43 am | ||||||
| Nebukadnezar |
Hahaha! Well, kinda hate to call you out on this, but that clearly would have been a better picture for my "polar to carpathian" filter: |
| Posted: April 29, 2012 5:51 am | ||||||
| Nebukadnezar |
As for your other examples, they surely look nice and I won't stop you, but there are other filters around that can do that with more options available.
The intended purpose of this filter is really just the single case, where you already have a radial image and want to apply an horizontal or vertical effect. (Better vertical, since the proportions get distorted horizontally, as Morgantao points out. But you are free to toy around with it, of course, and use it to your advantage. Adding a horizontal skew for example will add a spiraling effect, like SpaceRays example for posts above this shows, if you read it from right to left.) If you then put the image with the parallel effect back to polar coordinates, you will have a radial effect. Which will necessarily taper, since what was the whole width of the image will converge to a single point. If you want evenly thick edges you could perhaps apply an edge detection or high pass on filled forms. So obviously that transformation should happen as lossless as possible, without loosing any part of the image. In fact I suspect FF will not touch the parts of the image that weren't changed during the conversion at all, because it figures out that the transformations of the conversion cancel each other out. @Morgantao: There is actually a filter by ThreeDee in the library, called "Radial Spokes". It might do what you are looking for. Basically what it does is taking a spoke at the vertical center of the image, how it is supposed to look later, transforms that to cartesian and gets the distorted shape you are looking for. |
| Posted: April 29, 2012 6:17 am | ||||||
Nebukadnezar, Thanks for the tip on ThreeDee's snippet, but it's WAY to complex for me to make it work for what I want it to do.
Maybe one day when brain transplant is possible, I'll get me one that could understand this. |
| Posted: April 29, 2012 1:18 pm | ||||||
| Nebukadnezar |
I guess they had no Lookup back then or free/radial gradients, so a lot of that can be simplified.
Just feed your single spoke into the leftmost Lookup of my Snippet, tile/offset that to the number you require and put it into the right Lookup. Be aware that it will be cropped a bit, though. |
| Posted: April 29, 2012 1:34 pm | ||||||
OK, that works much better |
| Posted: April 29, 2012 4:07 pm | ||||||
15,390 Registered Users
+15 new last day!
+21 new last day!
10,103 Topics
+15 new in 7 days!
Totte, 18 unregistered users.
