had this filter since v2 and always end up putting it away out of frustration of not working out a solution. The problem is that this filter [ Tapestry ] I want to run stitching around the edges, with the stitches running along in the right direction. Here is a sample pic with poor edge stitching, anyone knows the answer it would be much appreciated, other wise this filters going in the bin |
| Posted: May 8, 2012 3:29 am | ||||||||||
I'm having trouble imagining how it's supposed to look. | |||||||||
| Posted: May 8, 2012 3:32 am | ||||||||||
Carl, whatever you do, PLEASE upload this filter!
I know it's not exactly the effect you're going for, but it could work very well for something I've always wanted. Uberzev, I think what Carl was going for is something like:
Or better yet, this:
Notice the stitching direction on the horse's mane. |
| Posted: May 8, 2012 5:59 am | ||||||||||
ronjonnie
Hi Everyone! Carl, that Stitching filter is AWESOME!! I agree with Morgantao, if you can't make it 100% let it go the way it is. Maybe you can call it Rough Stich or something? Very cool anyway, don't throw it away please! Have a gread day / evening! Later, Ron zazzle.com/Ronspassionfordesign*
So much to learn, so little time. |
| Posted: May 8, 2012 1:03 pm | ||||||||||
First of all, I like Morgantao and ronjonnie ALSO think that this should be uploaded OR put in the forum instead of throwing it aways, although perhaps is not what YOU want, this is really awesome and very WELL DONE the stitching effect.
Also you can give an option to have the stitching THIS WAY that is ALSO looking good and interesting AND also if you can do it YOUR way would be good too, but I think that BOTH ways could be available so you can choose.
Do you mean that you want that the filter finds the edges and then make a stitching all along that edge AND that the stitching goes in the same way of the edge SHAPE? I can suggest that perhaps you can draw by hand over the example HOW the stitching should really be according to your own idea. I that Morgantao have put great examples of directional stitching and here I have others that shows stitching on edges, although obviously here the edges are CLEARLY defined and what you want is a WAY to find the edges.
| Posted: May 8, 2012 4:43 pm | ||||||||||
morgan I whish I could get it to look as good as those samples Sample shows original .... without edge stitching ..... with a poor excuse of stitching. White background was roughly put back in, in PS, contrast in the filter need fixing as well, which I'll get to |
| Posted: May 9, 2012 2:55 am | ||||||||||
ronjonnie
Hi Everyone! Hey Carl, Do hope you can fix it, we will all be waiting for this outstanding EP Filter! Have a great day / evening! Ron zazzle.com/Ronspassionfordesign*
| Posted: May 9, 2012 9:17 am | ||||||||||
Carl, for the love of all that's holy, and some that is unholy,
UPLOAD THE FILTER! I love it the way it is now. You can alsways update later |
| Posted: May 9, 2012 2:30 pm | ||||||||||
[QUOTo]Morgantao wrote:
UPLOAD THE FILTER! I love it the way it is now. You can alsways update later[/QUOTE] YES, I agree with this. This well done as it is now. I know that it will not work right for small selections, small details or for text, but you can always update it and make it better later AND if you upload it to the library others could be able to help you make it better and get it the way you want it, if it would be possible in some way |
| Posted: May 9, 2012 10:33 pm | ||||||||||
I dunno, the Lambo text looks great to me Perhaps you mean much smaller text, in that case, stitching and embroydery are never a good idea. |
| Posted: May 9, 2012 11:34 pm | ||||||||||
Sorry that I have to disagree in this one, but I do not think that the Lambo text looks good, the example you have put of the Porsche is really well done. I think that Carl is right in that the text does not look good as it is now Compare the Lambo text with your own example and I think that the text would be much better like the one here below if there could be a way to make it like this
In photoshop I think is easier because you have more tools to make it and probably they are using vector paths, that are not yet available in FF |
| Posted: May 9, 2012 11:47 pm | ||||||||||
Well actually those examples I put here are actual embroyded logos. It's made with a special sawing machine that has a very special software designed only for those things... I agree that the text in the lambo is not at all the same as it is in the porsche, but I still like it much. It's a different style, and I like them both. Each style would have it's own uses, naturally. |
| Posted: May 10, 2012 1:57 am | ||||||||||
No, I knew that this comes fr om that special embrodery machines that can makes amazing specific designs with special software for making this BUT I really have seen this same kind of Porsche logo done in Photoshop with an action and from a plain text source, I have searched for an example to show it but I do not remember wh ere I have seen it. |
| Posted: May 10, 2012 2:40 am | ||||||||||
I haven't seen the example you're refering to, but I agree that with paths it's extremely easy to do the text in photoshop.
All you need is to set up a directional brush that like kinda like: |||||||| and have it follow a path outline of the letters you want. The problem is, as you said, that FF doesn't have paths yet. |
| Posted: May 10, 2012 2:50 am | ||||||||||
The option of edge stitching gives it much more versatility, but unfortunatly no one seems to have a solution, in case anyone didn't understand the problem I'm attaching a very basic example done ps, ..... if you can follow the edge, a more complex stitching could be easily bombed. I'm starting to beleive it's not possible in FF or requires some clever scripting |
| Posted: May 10, 2012 6:06 am | ||||||||||
Wouldn't Stitched Up by Mongoose King help you in any way to follow the path?
Also look at http://www.filterforge.com/forum/read...ssage97700 and check out the bomber examples he put there. |
| Posted: May 10, 2012 7:28 am | ||||||||||
Good suggestion, I just had a look in side the filter and tried to see whether it could be adapted, it uses a method great for gradient shapes, unfortunatly not suitable for edge detected following .......... again I think scripting is the only answer ........ it's a challenge for a scripter and could be used in many other ways in filter |
| Posted: May 10, 2012 9:43 pm | ||||||||||
I hope and wish that you or anyone else can find a way to make this edge stitching as I think it would be very interesting and useful to be able to do this.
Please, do not give up, because I think the reward is very good. |
| Posted: May 11, 2012 2:54 am | ||||||||||
Pretty sure I have a technique for this | |||||||||
| Posted: May 11, 2012 2:59 am | ||||||||||
Which is...? |
| Posted: May 11, 2012 5:42 am | ||||||||||
Please, show us that you are really the great genius, clever and expert filter forger that you have showed already in other many filters and projects. Please, do it again. |
| Posted: May 11, 2012 12:25 pm | ||||||||||
There are some techniques which can get pretty close to this. check out this thread: LINK
Both Sphinx's and Mike Blackney's solutions can be really useful, depending on what you're doing. Mike's uses a kind of marching ants routine, which is good for linear things. http://www.filterforge.com/upload/for...%205.ffxml http://www.filterforge.com/upload/for...0X01.ffxml Note that these are all done WITHOUT the use of the edge finder node. |
| Posted: May 11, 2012 3:46 pm | ||||||||||
Mongoose King
Now that there is an impressive image, there's another good one on that thread that shows it with stars all along the edge, so presumably the same can be done with a textured thread particle..
Will have to try this out for a new version of the Stitched Up filter.. Release the Mongoose! |
| Posted: May 11, 2012 4:19 pm | ||||||||||
the marching ants looks a lot better than my attempts, has difficulty finding all the edges, thanks for links much appreciated
I would love to see it, especially if you are using the bomber or in fact any way your doing it as the previous isn't a perfect solution and I have great confidence in your skill
cool, have to see how yours turns out |
| Posted: May 11, 2012 11:44 pm | ||||||||||
I wish that you can find a solution for this and that it would work as you want, and hope that you can find it as it would be very good and interesting. If is not impossible, I am sure that all you FF experts can find a way to do it, you are clever and smart enough with great skills to be able to reach to a succesful result.
Uberzev could have a good help on this, but of course he is not the only one. |
| Posted: May 12, 2012 2:37 pm | ||||||||||
Yep, Obi-Wan is. Carl, I would love to see you succeed in finding the solution you are looking for. But even if you don't have the outline stitching, the filter could still be very useful. |
| Posted: May 12, 2012 4:47 pm | ||||||||||
Sure! Both the marching ants technique and the derivative / offset method are going to be vastly faster and more precise than any bomber method. It really just matters what you're feeding it. btw: The stars thing is actually easy to do: it's just a matter of a lookup node and repeating the gradient. btw2: The thing that I want is a FF node that does a gradient from an arbitrary shape- Exactly like the Photoshop 'Outer Glow' or 'Inner Glow'. If you had that, then you could easily do dashed lines around arbitrary input shapes. Again, I have no idea why FF doesn't already have this very basic functionality ... btw3: I was thinking that there may be some way to do the derivative / offset method better somehow by breaking the input shape into somekind of regular chunks. That might allow it have a maximum distance that it distributes the dashed across straight horizontal and vertical lines. Sort of split the difference w/ the marching ants method. |
| Posted: May 14, 2012 3:30 pm | ||||||||||
ok cool
could idea, they would be very handy
I will release it soon as I spit and polish it |
| Posted: May 16, 2012 3:52 am | ||||||||||
Perhaps you could also use one of these
I know that there is no FILTER polish cream, but perhaps could be good to make the filter more shiny Or this |
| Posted: May 16, 2012 4:05 am | ||||||||||
LOL I'm just glad you didn't put examples of the spit |
| Posted: May 16, 2012 6:13 pm | ||||||||||
Mongoose King
Here's my attempt at stitching with the expanded marching ants method... It use a lookup to put in a stitch, cant really see in this example as the stitches are pretty small but they are proper little stitches with stitchey thread texture on them.![]() Release the Mongoose! |
| Posted: May 31, 2012 8:51 pm | ||||||||||
thats looking great |
| Posted: May 31, 2012 8:57 pm | ||||||||||
Holly smokes! This looks AWSOME.
Only thing that you should change is the "grid" of the stitching. Maybe add a little distortion. |
| Posted: June 1, 2012 2:36 am | ||||||||||
Mongoose King
Yea, background fabric isn't done yet, I'll probably pull the one from my old filter or some other fabric filter.
I just upgraded to 3.0 after I saw the 70% offer had returned for upgrades, so I'm still playing with the new hoobadoobs, I wana try n do stitching one image over another so you can use your own fabric texture etc. Release the Mongoose! |
| Posted: June 1, 2012 6:51 am | ||||||||||
That's actually not what I ment In the attached photo I have highlighted what I mean. The stitching looks a little too ordered in some areas, as if there's a bunch of stripes masking the stitch thread. Don't get me wrong, I'd use your filter in a heart beat, just if you wanna try and change something about it, this is a suggestion. |
| Posted: June 1, 2012 8:28 am | ||||||||||
Mongoose King
oh right, I get what you mean. Yea, problem is, that's pretty much what's happening when it does the marching ants thing, it just does 4 difernt directions of gradients and uses maths stuff to work out which matches the line direction best.. I could try making it a little bit wonkey to make it a bit less noticeable. I'm sure i'll tweak it a bit more before it's ready.
I'm more concerned with the problem that there's a few chopped in half stitches and little runty dot stitches that need smoothing out.. Release the Mongoose! |
| Posted: June 1, 2012 1:55 pm | ||||||||||
I don't know how these would look like in high res render, but right now they look like real thread defects. Most stitches in the world are not perfect, so having those "runty dots" just adds to realism. And the chopped threads look like tiny defects in the thread itself, also adding to realism. |
| Posted: June 1, 2012 4:05 pm | ||||||||||
Mongoose King:
That's looking great! Were you going to upload the FFXML? If you wanted to smooth it out, you could add more directions, maybe. (6?) IIRC, it doesn't need to be orthagonal. Some marching ants (Pshop) will use up to 8 directions. I have the sudden urge to make a BlueJeans-ification filter |
| Posted: June 1, 2012 8:17 pm | ||||||||||
Mongoose King
Jeans filter is totally what I wana go for too. I wana do a jeans effect with seams alongside the stitching and all the wear in the right places etc.. Release the Mongoose! |
| Posted: June 4, 2012 6:49 pm | ||||||||||
Please, keep on working on this that surely you wil be able to get it right as you want it.
I have found this that perhaps could help. It is an action for making Jeans stitching for Photoshop and curiously the author is called Vladimir must be said that the source for making all the below examples are totally plain black shape.
You can see more in this link |
| Posted: June 4, 2012 8:54 pm | ||||||||||
That's examples are fantastic SpaceRay. Photoshop actions should be easily translatable. | |||||||||
| Posted: June 4, 2012 9:16 pm | ||||||||||
Glad you like them uberzev
Can this really be done easily ? And what happens if the action uses the vectors and paths of Photoshop to make it ?Because this is not available in FF As you liked the above one, there is ANOTHER similar Photoshop action for Jeans Stitching
See this other one in this link |
| Posted: June 4, 2012 10:08 pm | ||||||||||
And some close up realistic stitching that is already done in Photoshop
| Posted: June 4, 2012 10:15 pm | ||||||||||
Yeah, I have made a long time ago a photo-to-comics action that I had to remade for photoshop cs5, and thought why not make it in FF? Well, apparently, I was using about 5 photoshop filters and techniques that are currently unavailable to us in FF. And don't take my word for it, even a higher authority (Inujima) said so |
| Posted: June 5, 2012 3:34 am | ||||||||||
15,510 Registered Users
+7 new last day!
+55 new last day!
10,191 Topics
+10 new last day!
