Login - Create Account
Bookmark and Share
Would be possible to create this Sphere of Spheres in FF?
I have seen this image that is attached below and thought that I this could be done with the Gradient Circles by Skybase perhaps making a selection, BUT I was wrong because I did not think that of course the textures will be cut at the selection edge and nothing will be out of the selection.
Perhaps there could be a way if the gradient circles filter did not make the bubbles/circles if the background was transparent.
Another possible way is to render the textures and then delete by hand all the circle/bubbles that were outside of the ball but this is too time consuming and very difficult to do.
Then I thought that could render a 2D version and use the Spherical Projection by inujima but this does not work as the bubbles/circles are deformed by the projection distorsion
So I am asking if anyone knows if this example below really could be possible to be done in FF in some way
Who are you?
Filters: 58
Think simple. It's easier than you imagine.
well done Skybase! Very good how you have done this.
I am sorry that I am not an expert like you, and it could be easy for you, but I have been thinking on how to make a masking or something similar to make this and I have not yet found the way.
Well. let´s see if it is simple and easier, I could use the Get Alpha to detect the transparency and then be able to make a mask so it does not show the circles on the transparent parts.
I have tried to use the Get Alpha and it works well BUT now all is in grayscale, surely I have made something wrong, I will see what is wrong and see how to fix it to recover the colors.
Here is one example
and this is with a circle
I know what happened I had put wrongly the blend component, Now I have fixed it and it works right in color as it should and with the shape that you would like smile:)
BUT even then, Skybase the example you have put looks better than the one I have got, perhaps you have added additional gradient or have done something extra to get that better look
So what have you changed?
Who are you?
Filters: 58
The easy solution = feed the selection component or any black and white image into chance 1 and chance 2 inputs of the bomber. Optionally you can feed the selection or the mask into the size or opacity parameter and turn down size/opacity-chaos. So those would be the changes.
I took some time off and just rewired the filter with additional features and fixes. It'll be in the library within the week.
Who are you?
Filters: 58
Some more modifications with the new setup....
Wel, I have only added a get alpha and a blend to join the source colors and the alpha
You can see it here below
Well, this may be the easy solution for you smile:D because I would never have imagined this, when you said "Think simple", I have done just that and found a simple fix. smile:)
WOW!! The new version looks really much better and makes really excellent, amazing and awesome bubbles/circles based on the source, I like them really much. Congratulations on this new version.
Thanks very much for taking the time to make this new much better version that looks so good.
smile:) Looks really cool, waiting for the update
15,411 Registered Users
+10 new last day!
+17 new last day!
10,110 Topics
25 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
