GF Optical Illusion (Spiro-wire) by Ghislaine http://www.filterforge.com/filters/10649.html |
| Posted: May 18, 2012 3:49 am | ||||
Like much your Spiro Wires optical illusions !!
Congratulations, AGAIN, for this well done filter, in this series of filters. |
| Posted: May 18, 2012 3:50 am | ||||
Yay, it's here I'm gonna have to try this one! |
| Posted: May 18, 2012 5:26 am | ||||
Thanks guys ! Here the .xml file for more presets, about 45 more. Let me know what this is done. Hoping that I did nothing wrong with this xml [ Library_10649.xml ] |
| Posted: May 18, 2012 8:43 am | ||||
Sorry, I have not been able to copy the XML file to the presets. Will wait until Morgantao tells what could be happening.
When copying and opening FF after it tells me that it is invalid |
| Posted: May 18, 2012 10:00 am | ||||
loving all your spirograph filters, ghislaine If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: May 18, 2012 11:10 am | ||||
To me it didn't have any error message about something invalid... It just didn't show the presets.
I'm working on it now. |
| Posted: May 18, 2012 2:18 pm | ||||
Fixed! [ Library_10649.xml ] |
| Posted: May 18, 2012 2:53 pm | ||||
I may have spoke too soon... Can you guys give it a go and see if all the presets match what you get when you render them?
For me there's a difference between what the preset icon shows, and what the real render gives. Also I have alot that are the same. Ghislaine, can you please upload the xml file again, maybe the same thing that gave the error message also corrupt the presets. Thanks! |
| Posted: May 18, 2012 3:02 pm | ||||
OK Here the xml [ Library_10649.xml ] |
| Posted: May 18, 2012 3:45 pm | ||||
OK, seems the file I uploaded should work.
The only weird thing is some of the preset thumbnails are different than the result I get on the render itself, unless I play with the "Type" control slider.... |
| Posted: May 18, 2012 4:45 pm | ||||
I will try this and see if I can add it.
I will delete the filter and so it cleans any possible problem, and then will download it again and put the new presets you have done Morgantao |
| Posted: May 19, 2012 4:47 am | ||||
YES!! It now works with your version of the presets Morgantao!!!
As said I have deleted the filter and downloaded it again
This does not happen to me |
| Posted: May 19, 2012 5:59 am | ||||
Look at this - I have many duplicate presets.
Example duplicates are marked in red: |
| Posted: May 19, 2012 10:28 am | ||||
And here are two presets, and the render I got from them below them. |
| Posted: May 19, 2012 10:30 am | ||||
SpaceRay, can you please post a screenshot of all your presets? | |||
| Posted: May 19, 2012 10:31 am | ||||
More Weird, when I first copied the presets the thumbnails have been the same as the ones you have posted in your screenshot BUT the result was the SAME as those thumbnails, and I found very strange that there was many repeating presets, BUT NOW when I open again FF and put this filter again it happens the same as you !!
Is true the thumbnails presets are NOT showing the real result!!
I will delete again the filter and will copy again the original presets from Ghislaine and see what happens. I think that we should TEST this in another thread and not continue littering the Ghislaine thread. |
| Posted: May 19, 2012 10:45 am | ||||
Good idea. We should also test it on other filters to see if it's a repeating problem. |
| Posted: May 19, 2012 10:52 am | ||||
I have deleted the filter (and the presets gets deleted too) and downloaded again and copied the presets from GHislaine in the second post and STILL I am getting the invalid error |
| Posted: May 19, 2012 10:54 am | ||||
PLEASE MORGANTAO CONTINUE IN THIS OTHER THREAD FOR A SOLUTION FOR THIS PRESET PROBLEM Problems when uploading the presets from another persons filter I AM SORRY GHISLAINE FOR ALL THE POSTS WITH THE PROBLEMS OF THE PRESETS |
| Posted: May 19, 2012 11:25 am | ||||
Mardar
I have a problem with this filter too! It is too damned fun to play with! LOL Love this filter Gigi.
This one with images. |
| Posted: May 20, 2012 12:13 pm | ||||
Very good examples Mardar !
I have fixed the 45 extra presets for you Ghislaine, I hope that now this time it works right. I have tested it and for me it works, let´s hope that for all of you too. This file must be copied to your "my presets" folder with your Filter Forge CLOSED. So next time you open FF it will have 45 extra presets. [ Library_10649.xml ] |
| Posted: May 20, 2012 12:28 pm | ||||
Ghislaine, can you please test SpaceRay's preset file, and tell us if it's the same as your actual presets that you have uploaded originaly?
I still have this feeling that some of the presets are not how you ment them to be. Thanks! |
| Posted: May 20, 2012 12:42 pm | ||||
I can´t be sure that the presets are EXACTLY the same as the ones from Ghislaine, because I have no reference on how the originals looks like. I have modified the code and the settings to be able to rebuild the presets and transfered the presets from the factory presets each one to user presets so it would be much easier to install and will have much less risk of not working. | |||
| Posted: May 20, 2012 1:19 pm | ||||
Here a screen of my 46 presets on the original that you must have the xml. You have to forget the first 20 presets you have on your image Morgan and Spaceray because I put the Spaceray last xml file in my presets folder, so these 46 presets do not appear in my 20 presets of the filter that I have uploaded. Dont know why Maybe because I get already those 46 presets on the original filter...
It seems that we do not have the same all images. |
| Posted: May 20, 2012 4:23 pm | ||||
I forgot to thank Kreallin and Mardar for their appreciation of this filter. Glad that you love it. Mardar your nice examples let me think to the wonderful scrapbookingwoman you are. I see your last pattern on the stuff you create. |
| Posted: May 21, 2012 9:46 am | ||||
lipebianc
Lots of fun with this one too!!! ![]() "From the moment we are born, we start being filtered..." |
| Posted: June 1, 2012 2:22 pm | ||||
Thanks Lipebianc. Glad that you have fun with this filter. |
| Posted: June 3, 2012 12:57 pm | ||||
15,512 Registered Users
+9 new last day!
+61 new last day!
10,193 Topics
+12 new last day!
Omnorimli, 6 unregistered users.
