In the rising filter trend of Spirograph, Spirograms, Spirostars, Spiro Wire, Spirography,Sine-o-graphs, and Wireframes, and similar styles (thanks to Ghislaine, uberzev, and Morgantao) I have seen that all this are based on LINES, different kind of them and different styles, BUT always the result comes from modifying and multiplying LINES (curves, circles, stars, or whatever shapes made with lines)
And WHY not use specially prepared and made images or photos for MAKING those Spirographs ?
Instead of using lines you would use simple objects that would be rotated a number of times around the same point and then create circular shapes based on this object
| Posted: May 27, 2012 3:52 pm |
Details
E-Mail
The above example is NOT really very good and does NOT show well my idea, but this is because I am just preparing it and seeing how this can be done.
This will be possible MAINLY thanks to the great work done by uberzev when he made the snippet or test filter for making spirography based on "bomber on the same spot"
And this was the source for my Spirography Break Out filter based on the unreleased filter of uberzev
I will make and put more examples that will show better what my idea is about when I prepare the special images and photos needed to be feed into my new filter that I am doing.
BE AWARE that when I am telling about PHOTOS, is NOT obviously NORMAL photos. |
| Posted: May 27, 2012 4:04 pm |
Details
E-Mail
For example if you have created this image shown below
| Posted: May 27, 2012 4:21 pm |
Details
E-Mail
And then you feed it into the filter you will get this shown below.
Although this is a very simple example, wait until you see what OTHER things you can rotate and you will the great potential of this idea, that can offer MUCH MORE than this
| Posted: May 27, 2012 4:24 pm |
Details
E-Mail
This is still very simple, please wait for more complex ones
| Posted: May 27, 2012 4:45 pm |
Details
E-Mail
Using this lightning photo as source object
| Posted: May 27, 2012 4:58 pm |
Details
E-Mail
You get this
The text is ALSO a PNG object
| Posted: May 27, 2012 5:00 pm |
Details
E-Mail
This is just the beginning and ONLY barely scratching the surface of what can be possible
| Posted: May 27, 2012 5:07 pm |
Details
E-Mail
Let´s BREAK OUT the design horizontally
| Posted: May 27, 2012 5:14 pm |
Details
E-Mail
and making multiply lines
| Posted: May 27, 2012 5:19 pm |
Details
E-Mail
Something very important, I will upload THESE interesting shapes in the filters page so you will be able to use them yourself with the filters as FF does not allow to submit external images with the filter, BUT I can offer them for you here in the forum
Horizontal and vertical Break Out
| Posted: May 27, 2012 5:25 pm |
Details
E-Mail
And this above is the basic part as this is with just ONE loaded external shape and without using the source image or the many blend modes.
Here is one mixing it with the source image
| Posted: May 27, 2012 5:30 pm |
Details
E-Mail
making vertical spirography break out and reducing much the tint color so all have about the same color overlay
| Posted: May 27, 2012 5:37 pm |
Details
E-Mail
Now using this simple image
| Posted: May 27, 2012 5:43 pm |
Details
E-Mail
You can get this
| Posted: May 27, 2012 5:45 pm |
Details
E-Mail
and if you multiply the object many times around itself you can get more complex ones
| Posted: May 27, 2012 5:49 pm |
Details
E-Mail
and the same as the one above but in color
| Posted: May 27, 2012 5:51 pm |
Details
E-Mail
back to the original rotated single spirograph with the above last simple object and using the Lionfish built in image
| Posted: May 27, 2012 5:59 pm |
Details
E-Mail
This could be good also for artistic portraits art
| Posted: May 28, 2012 3:45 am |
Details
E-Mail
Also for loading textures as main image and adding the spirographs result with one of the available blend modes (specially luminosity and color blend modes) adn get a customized texture like for example this one below
| Posted: May 28, 2012 3:54 am |
Details
E-Mail
or this other one more complex
| Posted: May 28, 2012 3:57 am |
Details
E-Mail
And for filling inside of text with this
| Posted: May 28, 2012 4:07 am |
Details
E-Mail
This is really good! |
| Posted: May 28, 2012 4:22 am |
Details
E-Mail
Thanks Morgantao, glad you like it.
I have tried many ways to do it mixing the blend modes or moving the textures and finally got it right.
All the examples shown in this thread are ONLY done with this filter I am making in Filter Forge without any postwork in Photoshop
The only thing from photoshop was making the text selection in the Filter Forge text example above |
| Posted: May 28, 2012 7:37 am |
Details
E-Mail
I have tried to use some pansies flowers with transparent background thinking that this would not work well, and I was wrong, they can be seen well and right
The main source image for colors is the built in kingsfisher
| Posted: May 29, 2012 4:25 pm |
Details
E-Mail
Also with just a number 6 or a simple little spiral !!! The image is a variation of the version 6 of my spirograms serie. The filter must be in the galery tomorrow.
| Posted: May 29, 2012 6:34 pm |
Details
E-Mail
I wanted to upload this filter to the library but is not possible as it is because it uses external images to work and without loading them, the presets with FF built-in image look very bad.
I will have to see if I can find another way to do it |
| Posted: February 15, 2013 3:45 am |
Details
E-Mail
