ycollings
Posts: 8 |
I just upgraded to FF3 and each time I attempt to access Tools > Options I freeze and crash. Anyone know why? thanks ! | |
| Posted: May 31, 2012 2:51 pm | ||
Do you get an error message, or does FF just closes? | |
| Posted: May 31, 2012 3:52 pm | ||
ycollings
Posts: 8 |
It just freezes, no error message, all I can do is shut it down and restart it |
| Posted: May 31, 2012 7:36 pm | ||
What's your computer configuration, and what OS are you using?
The more info you give, the better. Also, try Emailing the support team with the same info. |
| Posted: June 1, 2012 2:27 am | ||
ycollings
Posts: 8 |
running vista, windows
Processor : AMD Anthalon 64 x 2 Dual Core processor + 2.2 GHz Memory: 3582 MB System Type : 32 bit Video Card : NVidia GTS GeForce 250 |
| Posted: June 1, 2012 10:07 am | ||
Posts: 1723 |
ycollings, does it happen in the standalone or in the plugin mode? | |
| Posted: June 4, 2012 4:43 am | ||
ycollings
Posts: 8 |
It happens when I use it as a standalone.
I use Version 3.008 When used as a host, with ps cs3 Happens only when I try to access Tools > Options It works fine when I don't touch any of the menu options No issues with filter rendering, doesn't happen when I am attempting to render anyone one filter in particular. |
| Posted: June 4, 2012 10:59 am | ||
If you say that FF3 is freezing, I may have a very good solution and possible fix for this
Please visit www.spaceray.co.uk or www.spaceray.com and you will be able to heat up FF so is not freezing anymore |
| Posted: June 4, 2012 2:54 pm | ||
15,375 Registered Users
+33 new in 7 days!
+90 new in 7 days!
10,102 Topics
+16 new in 7 days!
20 unregistered users.
