angelize
angelize
Filters: 17
Hi all I'm starting this thread to report my findings while testing both FF3 and FF4 with Xara as a host. For the most part the programs work well together and I have been enjoying using Filter forge.
I am using Xara Designer Pro X
Windows 7 64 bit system
The first thing, is that Xara applies plugins as a "live" effect what that means is that if I create an image and apply an effect I can manipulate that image (resize it stretch it, rotate it etc. and Xara will re apply the effect at the dpi I specify. However this seems to create a problem with both versions of FF and if I do not lock the effect so the program can't reapply it I get an error. It would be really good if this could be fixed so users of Xara could take advantage of the Live effect features of the software.
Does Photoshop has a similar "live" effect as well? If yes, can anyone confirm FF works correctly with live effects in Photoshop?
Bionic
Don't think so, I use mostly Photoshop.
Further description for this feature and a short video.
http://www.xara.com/eu/products/desig...nced/#4624
http://www.xara.com/eu/products/desig...ures/#6144
Live Effects are plug-in effects that can be applied to any object, including vector drawings. They are called Live Effects because the vector object remains editable after applying the effect - when you edit the object, the Live Effect is re-applied automatically to the new shape.
Adobe Photoshop® plug-ins, both free and commercial, already exist for creating a range of effects that would take a lifetime to explore - metallic effects, color and image distortions, glows, water ripples, bevels etc etc. We have included a selection of the best Photoshop plug-ins that work as Live Effects in Xara Designer.
angelize
angelize
Filters: 17
I can also confirm that other plugins will work fine with Xara as a live effect and as Xara is actually a vector illustration program that does a whole lot more, being able to take advantage of Filter Forge and Xara's live effects would be great.
With Xara you can apply most PS plugins to pretty much anything you can create, vector shapes, photos or 3D extrusions. You can set the dpi that the plug ins automatically render at in the program options and if you are working with vector shapes the Live effects will be completely scalable. That is if you have them set at 300dpi it won't matter if your shape is 100px and you resize it to 10,000px your plugin still renders at 300dpi
Currently the issue I have reported here means that the effects have to be locked in Xara. They are still very usable when locked, but no longer live and scalable.
I also have a suggestion for the Filter Forge Developers
One thing that is really intuitive when working with Xara is the fact that anything can be duplicated by right click and drag. Would it be possible to have a feature like this in filter forge where you could right click and drag to create a copy of a component?
Sharandra
Filter Forge Addict
Guessing from Bionic´s quote, I think, the Photoshop equivalent to Live Effects would be Smart Objects with Smart Filters.
angelize
angelize
Filters: 17
Here is another error I encounter in both FF3 and 4 with Xara this one comes up if I cancel the application of the filter from within FF
angelize
angelize
Filters: 17
There was a recent upadate for version 3 and up till now the updates have run smoothly but this time when I started the upload process while using it as a plug in with Xara the download timed out at 66.3 of 66.4
I was able to do run the update no problem by using it as a stand alone.
It doesn't really matter if you update a plugin or a standalone version. Looks like you had a temporary Internet outage.
angelize
angelize
Filters: 17
Hi everyone. I noticed that there was an update and that FF now works with PS Elements 11 and Serif photoplus x6 Any news on whether Xara programs will be added to this list?
While Filter forge certainly is usable and very useful in Xara programs the above mentioned bugs still exist and filter forge needs to be manually installed.
angelize
angelize
Filters: 17
Hi everyone. There have been a new versions of Xara software released that support plugins So I am now testing with Designer Pro 9. The filters work very well however in addition to the errors I've already reported I've found that FF kicks up an error similar to the one in my first post in this thread when trying to apply the filter to a bevelled object. I've been able to work around that error by converting to a png with alpha before applying the filter but it is an extra step.
Frances, we can't add Xara as a supported host until this live effect issue is resolved, and this doesn't seem an easy thing to fix. All our resources are currently put into finalizing FF4. Feel free to poke me again some day after FF4 is released.
By the way, do our competitors work correctly with live effects? I mean onOne and Topaz software.
angelize
angelize
Filters: 17
Hi GMM thanks for responding smile:) I do understand that you need to get FF4 finalized and released. I just thought as I find these issues I'd post them here and you guys would have a list.
Yes most other plug ins work well with Xara's live effects. Alien Skin plugins work very well except for the new Eye Candy 7 plugins. They broke something when they did the re write for the new Adobe programs. But version 6 of EC works nicely. Alien Skin how ever don't want to bother fixing the version 7 plugins for use with Xara they want to cater to PS. Akvis programs work fine. I don't have the topaz plug ins but I have seen others on the Xara forums say that they are good. I think I tried a demo of a onOne product and it worked fine but I didn't want to spend the money at the time.
I'm also working on a line of filters that work with Xara's vector selections. I'm bringing the vector image in as an external image and setting an alpha channel. I'm also for some of these Xara friendly filters distorting the edges based on the texture being applied, for example text with a hair texture that actually looks hairy and not just filled with a hair texture. I hope to have the first one ready for library submission soon it's a metallic surface filter similar to Eye Candy's Chrome filter. It was doing this that I ran into the issue with Xara's beveled objects causing the FF error.
