I'm working on a filter right now and I need the internal components to be able to render seamlessly, but if I do the seamless override, I can't render a non-square image without it cutting off the right side of the image that's not square.
My suggestion is one or both of two. Either override the final crop of a non-integer aspect image of a seamless render, or allow an internal seamless tiling that allows components to be seamless but not to the user.
Maybe it would be a per-component setting like "Force seamless tiling" because what if you want to use blurs but the seamless tiling setting blends them with the other side of the image. so for some components you might need it on and some you might need it off.
Like seriously? It already rendered the rest of the image I should just be able to use it. Maybe a save option where I could check and uncheck something called "Delete unused pixels"
