Ken
CameraKen
Filters: 16
Ken
CameraKen
Filters: 16
Here is an example of 35mm Frame. I added the frame numbers in Photoshop
(Picture from Stock Exchange)
Ken
Ken
CameraKen
Filters: 16
I have just spotted a small problem with this filter. Setting the ‘size, pixels’ to about 143 or 153 or 170 causes the sprocket holes to have an extra slit in them.smile:?:
I will send an update as soon as I find the solution. Although the filter scales better if ‘size, pixels’ is set above 180.
In the meantime here is another example. This time a negative.
Ken.
Ken wrote:
153 or 170 causes the sprocket holes to have an extra slit in them.Question I will send an update as soon as I find the solution. Although the filter scales better if ‘size, pixels’ is set above 180.
Thats why one hour developing is sometimes not so good...Even still this is a really cool filter.. :afro:
(Digital 35mm Film) odd to say.
Ken
CameraKen
Filters: 16
There is now a Fixed Update available in the library. This works perfectly at all ‘size, pixels’. It now uses fewer components and so should work a little quicker.
Thanks.
The Sprocket holes are now fixed. So now this Filter should fit perfectly into your cameras memory card slot. smile:)
Ken.
Ken
CameraKen
Filters: 16
Also useful for video titles or web pages.
voldemort
voldemort
Filters: 649
nice one I like how you did the height on that frame it looks good gives it some nice depth
I was trying to something vaguely along the lines of variation #4/#7 and couldn't get the background, and the surface frame, to be 100% seperate depth-wise. I could borrow the wiring from yours, but I think I'll just scrap the whole concept and just say congrats to you on a good seperation effect instead. smile:)
+12 new in 30 days!
