Burt
Random Old Guy
This may be a baby question but what is the best way to get a Free Gradient to rotate in 90 degree increments the same way that the Profile Gradient does? I want to replace all the Profile Gradients in a filter but don't want to try to sort out all those rotations. I want play around with the XY Anchor available on the Free gradient to see if I can create a landscape mode version of a filter - right now only square and if I change the image there is an obvious line in the midddle. I guess I can feed all the Profile gradients into a Free Gradient but not sure if that is the best or only way as it would double the number of gradients.
You can create it this way for one.... smile;)
Grad.ffxml
Burt
Random Old Guy
Seems like there are so many ways to do the same thing in FF (in most great tools I guess). Thanks for the sample. smile:)
You are welcome.. smile:)
Yep thats one of the things I like to do is figure out how many ways to do the same thing...For instance there is another way to get a profile gradient...Although this one is not a non-square.... smile;) smile:)
Burt
Random Old Guy
Cool. Yes it is easy to get caught up with FF. smile:)
I want to thanks very much for the given filter to show how to get the same result of a Profile gradient with a Free Gradient and it works very well
Yes, I was trying to use rotate component to move the default angle of the free gradient but did not get exactly the same result, so I searched in the forum and found this thread with this great fix from you
Size Independent Profile Gradient filter
Size Independent Profile Gradient By Smacky
I have also found this filter that may be another different way to do it
+12 new in 30 days!
