lords8n
x
Filters: 10
Here's a few things I found might be useful.
1) Groups: The ability to group a branch of objects so they can be more logically viewed, move, and handled. Having more than 50 objects in several branches becomes cluttered and difficult to manage.
1b) Group Extended: Have the ability to affect a groups profile, etc... And a result plug off of an entire group.
2) Math: I know I posted this earlier in the form of a direct issue I was having, but I feel having a way to put a formula into the ReMapping of a control would be advantageous. In some instances I have found I want to affect a number linearly to one object, but on a formula curve to another at the same time.
So there you have it!
I'll hit back with anything else I can think of as the ideas arise.
lords8n wrote:
1) Groups:
Yes, already planned.
lords8n wrote:
2) Math:
Math for controls has been requested before, and is already on our list. Math for images is already planned.
What do you mean under the group's profile?
lords8n
x
Filters: 10
I was thinking that you could plug in a profile object to affect an entire group.
I'm kind of an amateur at this so I don't know if i'm splaining right.
vlad, i think he means something like, make a selection of a 'group' of components and stick a node on the selection itself, not on any given component within, and then plug something into that selection node. it would have a global effect on all components within the group.... i think smile:)
lords8n
x
Filters: 10
Yes, that's it.
Nodes on both sides though.
All I could think of that would be viable with my limited knowledge is one of those blue input nodes that I often connect curves to.
The output node would be a simple result node maybe.
You mean the curve components?
http://www.filterforge.com/more/help/...nents.html
If yes, what do you mean under 'affecting an entire group'? You can plug an entire subtree into Tone Curve component and feed a single curve into it. Is that what you want to do?
Also, we would understand each other better if you used our official terminology for things -- components, inputs, outputs, connections, etc. It can be found here:
http://www.filterforge.com/more/help/...ditor.html
lords8n
x
Filters: 10
Sorry I took so long to reply here.
Yes, I do mean a curve component input connection into the group with a result output connection out of the group.
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
22 unregistered users.
