Ken
CameraKen
Filters: 16
Hi
I wrote a little program
It gives a filter a Speed Rating based on the number and type of components within the filter.
I thought it may be useful to check how fast a filter may work.
This program can also create a log file which is saved in the same location as the filter with the name "(filtername).txt". This text file lists the filter components and shows how they connect to each other. It is not a complete flowchart as it stops at multiple input components such as blends and other components with multiple inputs. It may help to debug a filter
Have a play with it and let me know if I can make any improvements.
How to Use
Download the attached Zip file "SpeedMeter.zip" to a location of your choice
Unzip SpeedMeter.exe
Double click SpeedMeter.exe to run it
File > Open and locate the filter to test
The Filter Speed will be Displayed
Use File > Save Log to create the debug file. The file will be called "(filtername).txt". and will be saved at the Test filter location. NB it will automatically overwrite any existing txt file of the same name.
You may find it easier to drop this program into
C:\Documents and Settings\YourName\Application Data\Filter Forge\My Filters
And create a desktop shortcut. That way the program will always open in the correct folder by default
(Coming soon)
'Filter Updater' to update all the old components to the latest versions. smile:)
Ken
Ken
CameraKen
Filters: 16
Hmmm. I can't seem to attach the file.
I've put it here
http://www.megaupload.com/?d=MQ1T5814
Ken.
Hey Ken Long time No see or type.. smile:D
So what would be a cutoff point of good speed and bad speed..Kind of a nifty utility.
Did some filters, I took Rocky Formations and Rotate Zoom.
Rocky Formations 165
Rotate Zoom 73
Quite a difference there..
Ken
CameraKen
Filters: 16
Hi CFandM
Thanks
I would suggest that any filter with a speed under 300 could be classed as fast.But that does not mean that slower filters are not useful. Some filters in the library get a rating of over 900 and there is a few which give a "out of range" error where I did not cater for such a large number of lines.
It may not be the most useful program but it was a learning curve for me.
The txt file may be useful to help debug a filter.
There is more we could do with the FFxml files. I am half way to writing an updater to update all the obsolete components to the latest versions.
I could also write something to align all the components in the editor.
And the search feature that Zev requested would also be easy to write
Ken.
Fluxtah
Ian Warwick
Filters: 11
This could be great in the filter library to indicate rendering speed on a filter page smile:)
welcome back, ken smile:)
nice ideas. hadnt even thought of coding the code. interesting. i'll bet there's a lot you could do with the ffxml stuff.
Ken
CameraKen
Filters: 16
We could write some code to write filters from scratch. A random component connected to another etc, we could invent thousands of filters per hour. The problem is that we would also have to write some code to check if the results were good or not. I think this would be way too difficult.
Ken,
yup. thought of that, writing in text form. but seems a bit backwards with a visual coding program like this.
but the batch writing might have real possibilities. an infinite number of monkeys sitting at an infinite number of typewriters... smile:) i can just see it now, CF submits 20,000 filters on sunday and another 20,000 on monday smile:)
Torley
Second Lifer
This sounds pretty cool — like Fluxtah said, sounds like it's a worthwhile feature request to show a filter's relative speed within FF itself. I could see it being useful if I'm pressed for a deadline and going through my collection.
I'm enjoying using Filter Forge to create http://torley.com/textures
Ken:
Hello,
I have just found this thread and it would be interesting to have this little program, BUT the link is from the now closed Megaupload, so it is not available anymore, could anyone that could have it, upload it again here?
Thanks very much
