Hippotizer
Hippotizer
Is there a simple way to just do the following things:
- Rotate a RGB Input (green nodes) by +-90°
- Add/Sub with saturation/overflow two RGB inputs
- Create Circles/Ellipses
There probably ARE workarounds for these, but please let me know if I missed the simple way..?
Hippotizer wrote:
- Rotate a RGB Input (green nodes) by +-90° - Add/Sub with saturation/overflow two RGB inputs - Create Circles/Ellipses
- Currently no rotation
- Add/Subtract are in development
- No circles/ellipses, but they are planned for future releases (along with Bomber components)
If you need a grid of circles/ellipses, you can use the Tiles component with rounded corners.
Hippotizer
Hippotizer
concerning rotation: a component that could do all of the following (depending on a mode (int) variable) would be useful:
Rotate +90°
col(x,y) = col(y,x)
Rotate -90°
col(x,y) = col(1-y,1-x)
Flip X
col(x,y) = col(1-x,y)
Flip Y
col(x,y) = col(x,1-y)
Flip XY
col(x,y) = col(1-x,1-y)
Mirror X
col(x,y) = (x > 0.5) ? col(0.5-x,y) : col(x,y)
Mirror Y
col(x,y) = (y > 0.5) ? col(x,0.5-y) : col(x,y)
Mirror XY
col(x,y) = ...
concerning Add/Sub: cool, looking forward to it!
concerning circles: yes, I already found this workaround! smile:)
Quasimondo
Quasimondo
Filters: 32
I've found a an easy way to create circles with the help of gradients. The problem with the tiles component is that the minimum amount of circles you get is 4 (AFAIK). I've just submitted the filter to the library, but it will probably take a while until it is approved.
Hmmm - it looks like we need an easy way to exchange filters or filter code. I guess one could probably take the xml file and post it.
Quasimondo
Quasimondo
Filters: 32
BTW - flipping an image in X and/or Y direction is also possible with the current toolset using the powerful offset component with some proper gradients. I've just submitted a demo of this technique. i've also managed to to an arbitrary rotation, but that one needs still a little bit of tweaking.
33,814 Registered Users
+13 new in 30 days!
+27 new in 30 days!
