rilos
rilos
Filters: 9
Hi together,
I have only one computer that has access to the internet, the other doesn't.
So I downloaded a lot of filters with the one on the web, and copied the filters
from the location ... docs_and_settings\USER\Application Data\filterforge\System\Library where the new filters occur when I download them.
Now, when I just copy them to the same location on the other computer, the new filters don't work.
I dont see the nee filters in the library and if I choose one from the List by <Filter> -> <locate Filter> I get the error message:
"Cannot load filter .... - you need to update the filter library structure. Connect and update now ?"
So it seems again, I need web-access?
How do I copy the new filters so that it works ?
Tanks a lot!
regards rilos
regards, rilos
Bella
Filter Forge, Inc.
You should also copy the "LibraryStructure.xml" file. This will update the library structure without connecting to the Internet.
It is stored in Documents and Settings\YOUR_USER_NAME\Application Data\Filter Forge\System.
rilos
rilos
Filters: 9
Thank you, Bella - I will try this.
I also copied the filters to the location in the programm files\system - folders.
Was that right, or does it disturb the system?
And I also copied the thumbnails, do I need them or does ff build them itself?
Thank you!
regards, rilos
aegean
was also gonna ask this - i work away alot and the desktop is far better than the laptop and I was wondering how i could just copy stuff across rather than repeating downloads
Thanks
Ae
Bella
Filter Forge, Inc.
rilos wrote:
I also copied the filters to the location in the programm files\system - folders. Was that right, or does it disturb the system?
This folder stores the default pack of filters Filter Forge is shipped with. You shouldn't have copied other filters here but if you did, it's not a catastrophe. Filter Forge should run smoothly nonetheless.
This was unnecessary. Filter Forge does render them itself.
rilos
rilos
Filters: 9
Thank you for your ansers, Bella!
What about generating my own Filter-folder-structure?
This would be helpfull as filter-amounts rise and rise.
regards, rilos
Bella
Filter Forge, Inc.
Currently it's impossible. But it's on our development plan smile;)
that's music to my ears!
+1
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
