Jon Watte
The alpha blending seems to be not right in Normal blend mode. Areas where particles overlap get brighter fringes at the edges of polygons, compared to the polygon fill. It looks a bit as if blending is done using "composite" blend instead of "pre-multiplied" blend.
Here's the image: note the bright outlines of the successive polygons, which I would not expect to be such.
Dmitry Sapelnikov
Filter Forge, Inc. AKA Egret
Filters: 5
It's not a bug. Blending with tint color produces this confusing effect.
Set Tint Amount to zero.
Jon Watte
But why? There's no reason it should have to. And, I agree: it's a confusing effect!
Redcap
Redcap
Filters: 100
There are a lot of different tint effects, the current one you are using is "color" change it to normal and you will get a normal effect.
Why not have the default be normal, because normally when tinting something, the color blend option give the best results. So for a default it is great, most of the time...
I second the question -- this effect is definitely not intended.
Jon, could you post the filter?
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
14 unregistered users.
