bettybop
bettybop
Why is filter forge so slow? Im using an Imac with plenty of memory and ram etc. Ive had this trial programme for less than 24 hours and already losing patience with it. Im also finding it really difficult to find any tuts for complete beginners to make their own filters.
Totte
Übernerd
Filters: 107
It is not slow (for what it accomplish), and for FilterForge, CPU count is what matters. There is a distinct difference in rendering on lets say an iMac with Core2Duo and a MacPro with 2 QuadCore Xeons, a very distinct difference. It is also vital that you have set it up in settings to use all CPUs (you can see that with the Activity Monitor as well if FF leaves anything to the rest).
Another factor is the size of the result, and if you use Ambient Occlusion, which can be very slow some times.
Check out the existing filters, some are fast, some are slow. And when making your own filters, you will soon learn the does and don'ts.
what model of iMAc you have, I mean, wich CPU does it have, as it is the most important thing for the speed of Filter Forge.
Yes, filter forge is slow on old computers, I have an AMD X2 4400 2,3 Ghz and the filters are slow, but it depends very much on wich filter you are using, because I have seen that some can get the results in some seconds, and some take several minutes, depending of which filter you use and the configuration you use, and very important also is the size of the result you want it to render.
So to try it choose different filters, and different sizes and configuration.
I have put already a thread about that could perhaps be interesting to you
What is the best and most important hardware for FF ? CPU ? RAM ?
http://www.filterforge.com/forum/read...5&TID=7353
33,831 Registered Users
+16 new in 7 days!
15,390 Topics
