Digital Smith
A Digital Smith
Filter forge can projection map an image into UV space allowing a seamless bridging of annoying seams
Example: a projection on a synthesized object (object was faked in Filter Forge)
to map a texture to an objects UVs,
Bake out a texture from x, y, and z gradients (not sure how to explain this)
here is an example of a cube
this give you the XYZ location of each pixel in the UV map
here is the baked map for the default Second Life male head
Here is the projected result
here it is in applied to the original mesh in a 3d application
Mesh with an unmodified checker board pattern applied to show UV seams and varying resolution
project UV.ffxml
Totte
Übernerd
Filters: 107
Jim, this is really cool work. I saw this before (but had problems replying from my phone, went out of signal, then forgot it).
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
12 unregistered users.
