R. A. Weaver
Mr.
Yup! I had a week of trying to figure the downloading mystery to a frustrating repetition of needing the newer issue so please download it from our website rhetoric (no need to quote it exactly because we all have seen it). At he point of yanking the last few hairs out of my head my resident tech did a clean install on a virgin machine without a hitch. Seems that it was the browser cache in firefox that was refusing to make way for the newer version. Trashed it (the Cache) and have had clear sailing. It's worth a try on any other uncooperative transfer issues I'm sure!
Hope this helps someone
Later, Weaver
Thank you, a good hint to solve a common problem. I will stick this thread.
ghostwheel
I have Chrome. The 3.0 plugin doesn't work and I can't load filters into 2.0.
Thanks for the tip!
Targos
Game Dev
Its not a solution here unfortunately. Also I cant download 2.0 filters into 3.0
AC
R. A. Weaver
Mr.
thanx. But, it didn't work this time...
Nexxxt....
annettep38
Sorry, does not work for me either. For three weeks I have not been able to download anything? what can I do? I would try the beta 4 but when I launched it all my filters were missing, it is my own I miss most..
PS have tried to use chrome, doesn't work either.
Happy Mistakes
Happy Mistakes
I have the same problem. I'm already sorry I ever purchased this app... Tech support does not answer e-mails, what a waste of my money.
What are you having issues with Happy smile:?: .......Just a long time user and author not an employee of FF... smile;) smile:)
Targos
Game Dev
You have to stick with this. Its annoying whenever there's an update which is kinda crazy because updates = new features, but its pretty much unavoidable. My advice is to try and get used to having to stop work and update every so often.
~A
Happy Mistakes
Happy Mistakes
No. It keeps asking to update, which I already did. Program is unusable because of it.
What version do you have?...
You can also go to the Tools Menu then select "Options" the select the "Online" tab and select not to check for updates....
Unhappy former user
Try going into your Applications folder and removing both Filter Forge and, in your Photoshop folder, go to Plug-ins and remove Filter Forge. Then download it again. This fix worked for me after spending months trying to get FF reinstalled after getting a new Mac and upgraded OS (no thanks to "Support"--I finally stumbled upon the idea myself after getting the silent treatment from them). I've just had the same endless notice to upgrade after upgrading and have lost about an hour fussing with this, when it occurred to me to try the same fix again. It seems to be working now... I'm holding my breath! What shoddy software. It should not cause this much frustration and require this much work just for an upgrade.
Swinn
Swinn
The problem is the plugin doesn't actually install in the plugins folder because of a permissions issue. Just drag the ENTIRE folder into the plugins directory and it will work.
GStartup
This is a constant source of irritation. A complete reinstall helps but I have the same problem several weeks later. It has happened 4-5 times and I am tired of re-installing. Wish they would fix this issue.
