johnt
I'm getting this error
<class XFW::StateError> Specular exponent 10000 is too large (greater than 10000) for environment 034C65F0.
Submitted a bug report and was told it was a corrupted environment and that I should redownload and install. I uninstalled, deleted the FF application data folder, downloaded and reinstalled and I still get the error.
Is there something else I need to remove before I reinstall? I'll be happy to post the bug report if it will help.
Thanks
johnt, please delete the Filter Forge 3\Environments\ folder, redownload and reinstall Filter Forge.
johnt
GMM,
Thanks for the reply. I uninstalled FF3 then checked to make sure the Filter Forge 3\Environments\ folder was gone. I also deleted the application data folder for filter forge then I downloaded a fresh copy of FF3 and reinstalled but it didn't solve the problem. Using only the filters that come with the install, the error occurs every time on some filters and never on others. I'll post a bug report tonight.
johnt
here is a bug report:
Operating system: Windows XP (5.1 build 2600) Service Pack 3
Physical memory: 3327 MB
Number of processors: 4, available: 4
Processor info: AMD Phenom™ II X4 B45 Processor, ~2991 MHz
Filter Forge x86-SSE2 3.007.23569.7090 Release-SSE2, February 13, 2012 14:14 [3/15/2012 10:09:27 PM Eastern Daylight Time]
Exception reported at thread 00000E00 'RenderingMgr 029E5E58/0':
<class XFW::StateError> Specular exponent 10000 is too large (greater than 10000) for environment 034C9F08.
Possible original exception location:
<unknown file>(0) : <unknown function>()+0 at 0072CFA5 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0490E7D8 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00C42E98 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00BC65C0 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 001B:7C812AFB, SS:ESP 0023:0490E6CC, EBP 0490E720, FLAGS 00000206
CONTEXT_INTEGER: EAX 0490E6D0, EBX 034D8388, ECX 00000000, EDX 00000000, ESI 0490E760, EDI 0490E760
CONTEXT_SEGMENTS: DS 0023, ES 0023, FS 003B, GS 0000
[FFXLib::RenderingManager] Failed filter dump:
<?xml version="1.0" encoding="utf-8"?>
<Filter>
<Components>
<Result id="result">
<Height source="tiles 02"/>
<Reflectivity value="1"/>
<ReflectionBlur value="0"/>
<Met allic value="0"/>
<FilterType value="1"/>
<Lighting>
<Height value="0.050000000000000003"/>
<Environment>
<Source value="Church"/>
<Saturation value="1"/>
<Rotation value="17.031000000000017"/>
<RotationAxis x="0" y="1" z="0"/>
</Environment>
<Ambience>
<AmbientLight red="0" green="0" blue="0"/>
<Shadowing value="0"/>
<CurrentOcclusionSettings>
<RayDirections value="4"/>
<TraceDistance value="0.20000000000000001"/>
<RayJittering value="true"/>
<RayBounce value="true"/>
<AvoidStreaks value="true"/>
<DirectSamples value="0"/>
<ROQuality value="3"/>
</CurrentOcclusionSettings>
<CustomOcclusionSettings>
<RayDirections value="16"/>
<TraceDistance value="0.29999999999999999"/>
<DirectSamples value="1"/>
<ROQuality value="10"/>
</CustomOcclusionSettings>
<ArtisticSettings>
<BlackPoint value="0"/>
<Midtones value="0.5"/>
<WhitePoint value="1"/>
</ArtisticSettings>
</Ambience>
</Lighting>
</Result>
<Blend5 id="blend5 01">
<Mode value="0"/>
<Foreground source="perlinnoise2 02" red="1" green="1" blue="1" alpha="1"/>
<Background source="perlinnoise2 03" red="0" green="0" blue="0" alpha="1"/>
<Opacity value="0.33000000000000002"/>
<CheckboxControl id="checkboxcontrol 01">
<Name value-en="Row Shift"/>
<UseRemapping value="false"/>
<Checked value="false"/>
</CheckboxControl>
<ColorControl id="colorcontrol 01">
<Name value-en="Color 1"/>
<Color red="0.91472900000000001" green="1" blue="0.93330900000000006" alpha="1"/>
<HDR value="false"/>
</ColorControl>
<ColorControl id="colorcontrol 02">
<Name value-en="Color 2"/>
<Color red="0.12661500000000001" green="0.66666700000000001" blue="0.26950800000000003" alpha="1"/>
</ColorControl>
<ColorControl id="colorcontrol 03">
<Name value-en="Mortar"/>
<Color red="0.28682200000000002" green="0.28682200000000002" blue="0.28682200000000002" alpha="1"/>
</ColorControl>
<Name value-en="Brick Type"/>
<Value value="1"/>
<RangeMax value="20"/>
<NoiseCurve id="noisecurve 01">
<Roughness value="0.20000000000000001"/>
<Amplitude value="0.5"/>
<Minimum value="0.33000000000000002"/>
<Maximum value="0.58999999999999997"/>
<Scale value="1.6000000000000001"/>
<Details value="0.40000000000000002"/>
<Variation value="1"/>
<Periodic value="true"/>
<Randomizable value="true"/>
</NoiseCurve>
<PerlinNoise2 id="perlinnoise2 01">
<Noise source="colorcontrol 01" red="1" green="1" blue="1" alpha="1"/>
<Roughness value="0.29999999999999999"/>
<Scale value="2.6899999999999999"/>
<Stretch value="0"/>
<Angle value="0"/>
<Details value="0.20000000000000001"/>
<Contrast value="0.58999999999999997"/>
<OctaveCurve source="noisecurve 01" value="0"/>
</PerlinNoise2>
<PerlinNoise2 id="perlinnoise2 02">
<Noise red="1" green="1" blue="1" alpha="1"/>
<Background red="0" green="0" blue="0" alpha="1"/>
<Angle value="0"/>
<Details value="1"/>
<Contrast value="0.25"/>
</PerlinNoise2>
<PerlinNoise2 id="perlinnoise2 03">
<Roughness value="0.23999999999999999"/>
<Scale value="2.3100000000000001"/>
<Angle value="0"/>
<OctaveCurve value="0"/>
</PerlinNoise2>
<SliderControl id="slidercontrol 01">
<Name value-en="Chaos"/>
<Value value="0.40000000000000002"/>
<Name value-en="H Range"/>
<UseRemapping value="true"/>
<Value value="1"/>
<Name value-en="L Range"/>
<Value value="0.5"/>
<Name value-en="S Range"/>
<Value value="0"/>
<Name value-en="Bevel Width"/>
<Value value="0.14999999999999999"/>
<Tiles id="tiles 01">
<Color source="perlinnoise2 01" red="0.69999999999999996" green="0.46600000000000003" blue="0.34999999999999998" alpha="1"/>
<Mortar source="colorcontrol 03" red="0" green="0" blue="0" alpha="1"/>
<HRange source="slidercontrol 02" value="0.050000000000000003">
<Minimum value="0"/>
<Maximum value="0.25"/>
</HRange>
<LRange source="slidercontrol 03" value="0.14999999999999999">
<Maximum value="1"/>
</LRange>
<MortarWidth value="0"/>
<BevelWidth source="slidercontrol 05" value="0.20000000000000001">
<Maximum value="0.29999999999999999"/>
<Corners value="0.10000000000000001"/>
<FillMode value="1"/>
<RowShift source="checkboxcontrol 01" value="false">
<Invert value="false"/>
</RowShift>
<RepeatH value="3"/>
<RepeatV value="3"/>
<Chaos source="slidercontrol 01" value="0.14999999999999999">
</Chaos>
</Tiles>
<Tiles id="tiles 02">
<Color source="blend5 01" red="0.69999999999999996" green="0.46600000000000003" blue="0.34999999999999998" alpha="1"/>
<Mortar red="0.36821700000000002" green="0.36821700000000002" blue="0.36821700000000002" alpha="1"/>
<HRange value="0"/>
<LRange value="0.59999999999999998"/>
</RowShift>
</Chaos>
<Bevel value="0"/>
</Tiles>
</Components>
<Presets>
<DefaultPreset preview_image="LIFESAVER_OPAQUE">
<Settings size_factor="2" variation="18535" seamless="false" antialiasing="2" map_type="0" edges_only="true" clip_hdr_for_result="true"/>
<Lighting>
<Environment>
<Brightness value="1"/>
</Environment>
<Ambience>
<ArtisticSettings>
</ArtisticSettings>
</Ambience>
</Lighting>
<Controls>
</CheckboxControl>
</ColorControl>
</ColorControl>
</ColorControl>
<Value value="1"/>
<Value value="0"/>
</Controls>
</DefaultPreset>
</Presets>
</Filter>
[FFXLib::RenderingManager] Rendering settings dump:
Seed: 18535
Seamless: false
Optimize blur radius: true
Supersample explicit inputs: false
Output size: 600x600
Sampling rate: 1
Supersampling kernel: 2
Jitter: 0
Bruteforce: false
High precision bitmap: false
Blend with original image: true
[FFXLib::RenderingManager] Rendering storage: <class FFX::PreviewRenderingStorage>@0349A3E8
[FFXLib::RenderingManager] Failed rendering block dump:
Block origin: 225;75
Root component: result
Progressive pass: 3
Exception caught at thread 00000B4C 'Application':
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
15 unregistered users.
