| Jon Watte |
This is using FF2.
Look at the below screen shot. The input data is black-to-white, but the output data has ugly black squares where the input data is at its whitest. Is this a problem where HDR data wraps from 255 back to 0? If so, is there a fix? I've looked for a "RGB clamp" operator for a color map, but can't find it. |
| Posted: August 10, 2010 11:21 am | ||||
Hi Jon,
Wow, that's truly messed up. It is definitely a bug. I did find one way to fix it. Here you go: Clamping.ffxml |
| Posted: August 10, 2010 11:57 am | ||||
| tigerAspect |
No, no fix, I cant't even get confirmation if this is a bug or not. I brought this up in the beta, and the official word is that an Elevation Gradient is apparently "numerically-unstable by nature". Go figure.
Discussion here: http://www.filterforge.com/forum/read...8&TID=7449 |
| Posted: August 11, 2010 10:11 am | ||||
| BenBeckwith |
It appears to be a bug with the Contrast param in the noises. When the contrast reaches beyond 0-1 it clamps to 0, but seemingly only with the elevation involved, because it looks fine in the noise alone. If you want that much contrast, try using HDR in the colors rather than the contrast slider. The contrast slider maxes out around 33 for the blocks noise and 64 on perlin.
| Posted: August 11, 2010 4:03 pm | ||||
| tigerAspect |
Nope, it's a bug in the rendering engine itself. Here's the official word so far, and the example referred to:
| Posted: August 11, 2010 8:16 pm | ||||
Do you have a situation that doesn't get fixed with the Tone Curve solution? |
| Posted: August 16, 2010 3:36 am | ||||
| tigerAspect |
Yeah, that's probably fine.
| Posted: August 16, 2010 10:11 am | ||||
| Jon Watte |
I'm a little late, but there is a code fix that should be simple: If the Elevation Gradient just clamped the input to the [0..1] range, instead of repeating, it would do fine. Specifically, there is a "repeat" parameter already. When that's set to 1, what reason is there to wrap instead of clamp for out-of-range inputs?
Alternatively, the output of the noise should clamp to [0..1] rather than wrap, if that is where the problem is. |
| Posted: September 13, 2010 3:46 pm | ||||
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
20 unregistered users.
