andyz
Filters: 5
The z coordinate in get_perlin_noise does not work as expected for me - its scale seems to be way off that of the x & y axis.
Normally with 3d perlin noise I can swap the x & z coordinates and get rougly similar results but in FF lua get_perlin_noise(x,y,0,10) is totally different to get_perlin_noise(0,y,x,10) because everything is stretched horizontally with the latter.
Why is the z scale different?
The 4th parameter of get_perlin_noise controls the "scale" of the x and y coordinates, but it does not seem to affect the z coordinate. The noise(0,y,x,scale) is not stretched when the scale is set to 500 or so.
Andyz, please attach or email a filter that would illustrate your issue.
andyz
Filters: 5
here is simple example
noiseproblem.ffxml
Andyz, yes, the Z coordinate of our perlin noise behaves differently. Our implementation of perlin noise was not intended to provide a full 3D noise. In our 2D adaptation of the Perlin Noise algorithm, the X and Y coordinates are special because the noise must be capable of seamlessly tiling itself along the XY plane, but not in the third dimension. The stretching you see is probably caused by the fact that the Z coordinate is not affected by the scale factor argument.
andyz
Filters: 5
Ok, I am doing something different from the norm (3d noise on a sphere for planets) but I used a LUA implementation of improved perlin noise which is actually very fast!
21 unregistered users.
