xirja
Idididoll Forcabbage
Can't seem to find a way to fix this skewing towards the center in each of the 4 regions. How to get a perfectly symmetrical scaling of a 2 repeat spherical gradient?
xirja
Just using the Scale component and hookups to the Origin X/Y preferably, what is the proper method?
ScaleTest.ffxml
xirja
The simple answer of course is to just use the .25 and .75 quadrant centers for the origins:
xirja
filter
ScaleTest2.ffxml
xirja
But to have the origins set by the initial image somehow, the closest I have found is a hybrid 50% normal blend:
xirja
filter3
ScaleTest3.ffxml
xirja
But it has to segment the image into quadrants in this case, which is not ideal. Any ideas on how to pinch a Perlin noise using the selfsame noise for example?
xirja
The consequences of such trivialities:
Do you mean this? Take the simple case of flat image. You want the origin X&Y to just be gradients (in other words, nothing happens).
You take the X & Y derivatives of the input. These are the slopes. There is a factor to choose how strong the slopes are. You offset those gradients by the slopes. Those are the new origins.
Or something like that. smile;)
Try plugging in a perlin!
Self Scaling.ffxml
xirja
Oh, that's the one! smile8) It's too early or I'm too old to fully comprehend this, but awesome and simple solution!
xirja
filter4
Self Scaling2.ffxml
xirja
I think this is another faster lighting/shadow method too, combining it with Sphinx's Elevation - Angle - Slope.ffxml to "tame" or normalize the derivative. smile:)
<- Refreshes memory on The rate of the rate of change / acceleration / second derivative, zoom, Zoom, ZOOM! smile:D
xirja
Using this method for both the scaling and for adding an additional light/color/shadow to a surface filter with 5 sample AA (edge only), in 30 sec we have:
xirja
Too much fun! The same filter and AA settings, different controls, 42 sec:
That's neat! You can also use this method to scale something by something else. I got this with the help of my vortex filter.
xirja
Totally, from where a million whirleds begin! smile;)
Speaking of your vortex filter, did you see the last post in your gallery? Specifically:
BTW, any further ideas on the spiral border?:
http://www.filterforge.com/forum/read...&TID=11150
Would love to save the stress of thinking that the border issue can be solved if it can't. smile:|
xirja
Any good recipe books for cooking up exceptional erosional noise combinations? This is driving me batty, but from suffering comes reward they say.
So, winging it, another step in the right direction perhaps. Really liking the (+Perlin -Cells +Perlin) elevation gradient with this fractal self scaling gem. Any suggestions on rivers and rocks and such?
David Roberson
Artist
Filters: 37
I'm totally with you on the quest for erosion! I always read threads referencing the topic hoping to spot a breakthrough.
Nice textures, BTW. Share? smile:D
David Roberson
Artist
Filters: 37
Ooo. Neat! My brain popped a fuse trying to parse, "+Perlin -Cells +Perlin" bit in your comment, though... How does that part translate in a node-network?
David Roberson
Artist
Filters: 37
That sounds like the very thing I've been trying to figure out! Would you care to elaborate? (I've got the filter(s), so I'll be playing with it to see what happens, however, I thought I should ask if there're additions required to do what you're referring to here, or if I'm likely to stumble on the answer myself just pushing and poking at it for a while...)
Thanks for the shares!
18 unregistered users.
